Echo CS 490 no start
/ Echo CS 490 no start #21
Update: still won't fire or start, after putting a bit of 2-cycle oil in cylinder and fresh pre-mixed fuel. Air filter on or off, no change. No more ether, although I spoke with a neighbor who does use it occasionally for his chain saws- and he's a retired engineer who worked with a military application drone company that used a lot of small 2 cycle engines, so he knows small engines. Anyway, I am now thinking I will pull the carb and clean it. I haven't squirted ether directly into the cylinder, and I won't, although that could rule out a carb problem.
I've got two of the CS-490.
I've learned the hard way to ALWAYS use canned fuel.
I use to pre-mix using non-ethanol but never again.
I don't tend to use my saws very often.
I change my air filters annually now and thoroughly clean my saws after every use.
2021 New Holland C327 Compact Track Loader (A57024)
2021 New Holland...
2013 International WorkStar 7400 Altec AM547 50ft. Bucket Truck (A59230)
2013 International...
2003 Honda Accord Sedan (A59231)
2003 Honda Accord...
2022 THOMPSON PUMP 6X6S1 PORTABLE PUMP (A59823)
2022 THOMPSON PUMP...
2004 VE ENTERPRISES 500BBL FRAC TANK (A58214)
2004 VE...
3-Stage Forklift Mast with Forks (A59228)
3-Stage Forklift...
