Does that engine have a valve adjustment procedure?The Robins are prone to having these pop out I understand. Terry was quick to suggest that that was the problem. The little sheet metal guide was bent a little, but I was able to get it back to where it should be. I still may order a new one.
[emoji[emoji6
]]ā hole in the top of the shroud so as to move the flywheel with a screwdriver. Of course I also lost a locknut and the threads are not standard. A couple new ones are on order. I pulled the metal shroud below the spark plug and cleaned the mess on the bottom of the tub looking for the nut. Nothing. From all the poking around the (now) rigid fuel line began to weep so that got replaced. Next I found the exhaust on one side was loose and the nuts were all in so I added washers and its snug now. This got me to wonder if it would have been easier to pull the engine. Are there lovejoy connections inside the housing adapter? I wish the rear of the PT opened up. Iāll probably look to pulling the engine come springtime so as to throughly cleaning out the tub.
ā home and moved the flywheel alone with a screwdriver to find TDC. My Ace Hardware had a plug that filled the hole.
