Easier way to move trailers with loader
/ Easier way to move trailers with loader #21
I got mine years ago from them. I like the new style, they changed it from what they did offer. I have to tilt mine up to see the ball. It works but sometimes makes it difficult to get the ball into the hitch.
I made one like that. I used a 1/4” thick skid steer plate and I bent it moving a loaded trailer. I should have used a 1/2” plate instead.
/ Easier way to move trailers with loader #22
After reading of people unable to see the trailer ball while moving trailers, I thought to post these pictures. FYI. I don't have trouble moving trailers and by tilting the bucket can usually see the ball. Moving is quick and easy.
I didn't make this thing but did heavily reinforce it after it bent under heavy trailers. I got it in Kentucky with a trade and these are not my welds. It just an extra long bucket clamp arrangement welded to a long style receiver tube. By using the long style hitch and ball, the extra length makes it easier to see except when the trailer is real low to the ground. Then I have to crook my neck or lean forward.
The extra-long makes it work and I can usually hook up in seconds. Surely others have made better so if you have a pic, post it.
View attachment 4006749 .View attachment 4006752 .View attachment 4006750 View attachment 4006752
Great for putting a smile in your bucket too.
The point of my using a small tractor is that it won't lift enough to bend the bucket. I've had this arrangement for 20 years and lifted many trailers and no bend yet. Think stuff out, don't overload your equipment and it's all good.
/ Easier way to move trailers with loader #24
May your good luck continue.
/ Easier way to move trailers with loader #25
/ Easier way to move trailers with loader #26
I first saw something similar back in the eighties. My Friends dad put a hitch on the front of his truck so he could back a boat down the side of house without hitting the fence. It was a long tight fit. I have a hitch plate for my SS and that is the best, as you can pivot the trailer axle without moving it forward or reverse. Much more controllable than the front of a loader.
/ Easier way to move trailers with loader #27
I just bought a new to me B2301 w/ LA434 loader to replace my B7510 w/LA302 loader. I welded a 2”x2”x3/8” angle between the loader arms with a lug for a ball. It fits behind the ssqa and doesn’t interfere at all. I had one on my B7510 as well (I made a kubota style qh for that bucket.) first two pics are the LA302 with the QH l built. Second two pics are the LA434 on the B2301
/ Easier way to move trailers with loader #28
I don’t know why tbn won’t let me add the other two pics in the other comment so here they are.
Not here either.
How large are the pics? there is a 2mb limit.
/ Easier way to move trailers with loader #29
It might be the format. Look at the picture properties. Ensure they are jpeg format.
On topic. A front end loader may be easier than a bumper hitch but for the ultimate in trailer moving control get a hitch on a skid steer. That's the ultimate control.
/ Easier way to move trailers with loader #31
You can get them plates cheaper w/ a removable receiver. Not sure of the strength, but says 3/8" throughout ~$170:
I can't see what is behind the $170 one as far as the backing plate reinforcements, on amazon but I like the Titan a lot better due to the strength of it. I just don't like the price, lol.
If I used my tractor to back trailers in very much, I would buy a blank SSQA plate and get a receiver hitch from a auto recycling yard and weld it on the front, similar to what Titan did.
David from jax
/ Easier way to move trailers with loader #32
I use a drop hitch on the FEL bucket. Works good, but depending on the trailer, can be hard to ‘spot’. Either way, it works good and can remove the hitch from the receiver when not in use.
/ Easier way to move trailers with loader #33
I've recently upgraded from a basic 25' fifth wheel to a 27' bumper pull with a slide. My GC will not lift the tongue. I've thought of making some sort of dolly that I could use with the tractor. Does anyone have any experience with this?
1408 (A57192)
1408 (A57192)
Adams 350T 10T Tender (A61306)
Adams 350T 10T...
2018 KOMATSU PC138USLC-11 EXCAVATOR (A60429)
2018 KOMATSU...
Location Info Please
JLG 600 AJ SKYPOWER BOOM LIFT (A60429)
JLG 600 AJ...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59905)
2019 INTERNATIONAL...
