Excellent, here are a few more pics. Now that it's at my parent's (until I get it running) it's a bit easier to inspect. The loader is a Massey Model 99. It's got a very narrow bucket, so it won't be very good for moving snow, but I'll change that out eventually. I'll make it work for this winter.
Let me know if there are any other/close up pics that you want to see. There really doesn't seem to be very much information on the Utility 35 that I can find. I guess it's more of a MF35 painted yellow, a bit more industrial/heavier duty? The front axle on mine is pretty beefy compared to some of the regular MF35 pictures I've seen online. I did, however, find this cool old ad regarding the Utility model, as seen below.
Edit: I can't seem to get the information on serial numbers on tractordata.com (
TractorData.com Massey Ferguson 35 tractor information ) to jive with mine. Weird. My guess is that it's a 1964, but I only suspect such because of other information I've come across online, none of which has to do with data tags.
Another question- are these tractors positive or negative ground? I've read both, and with as little info as I can find out mine I'd like to be sure before I try jump starting it/hooking a battery up. There are no battery cables on mine, the ground has been removed (though I think I see where it goes) and the positive has been cut at the starter.
Edit again to add more information. I've found that the first three digits of my serial number- UGM =
U utility
G gas (6:1)
M dual clutch
