E Hydro oil Question
/ E Hydro oil Question #1
Kubota 2350
Platinum Member
Michigan, In The Thumb
2016 JD 3046R Cab ...................... Mower: 2016 Scag Tiger Cat II ZTM
I have a JD 4310 E Hydro and I'm getting ready to change the trans oil, the dealer sold me Hy-Gard low vis for year around use.
After looking in the manual I see that this oil is only recommenced for up to 80 degrees.
Is this right? I can use just plain Hy-Gard, but not sure about winter use.
What do you guy's use that have hot and cold weather?
I use the tractor for snow removal in winter, and brush hog, and tiller in the summer.
Kind of at a loss here.
/ E Hydro oil Question #2
Lo-Vis is the correct stuff.
Dunno where you got your info for 80 degrees but this is what I found from Deere:
/ E Hydro oil Question #3
For the reason Dave points out I use low viscosity year round. There is a small, probably unworthy of mentioning but noticable performance difference: the FEL bucket when full of heavy material tends to "flop" empty on hot days with low-vis compared to hi-vis. But it doesn't take very long to develop a feel for it and compensate.
/ E Hydro oil Question #4
And to be fair and balanced, at -20F during the winter the tractor moves much more readily with low-vis!
/ E Hydro oil Question #5
Down here in North Carolina, my dealer buys much more hy-gard than low viscosity hy-gard. I run the low-vis in my JD318 garden tractor because I use it for snow removal. When I change out the hydro oil in my JD4520 CUT, I'll switch to plain 'ol hy-gard. Due to volumes, dealer has better price and machine is primarily for mowing and will see little winter use when it's below freezing.
If I was back in New England, I would run lo-vis. So like many such oil decisions, it's "where are you" and "what are you doing".
Pete
Could you define "flop" for me please?:newhere:
/ E Hydro oil Question #7
Flop - in this usage, an intransitive verb:
1: to swing or move loosely
2: to change or turn suddenly
With hi-vis, dumping the bucket either heavily or lightly loaded resulted in the same steady, predictable, uniform movement.
With lo-vis, on hot days and with a heavy load like wet clay soil, dump acceleration was much higher and terminal velocity faster.
It was the unexpected increased acceleration that caught my attention, as I was in the middle of excavating soil from the 100ft road I was building when the changeover from hi-vis to low-vis occured. Otherwise I may not have noticed.
OK, Mine will dump very fast at the very end of the dump cycle, other than that I have no problems.
Tractor has always done that though.
Probably already has low vis in it.
Thanks
/ E Hydro oil Question #9
So what are you paying for 20liters of trans/hydraulic oil now? It was about $20 when I bought my 4300, now its over twice that, but its still the same price as straight hydraulic oil....
2009 Infiniti G37 Coupe (A64557)
2009 Infiniti G37...
Bobcat 60� Rotary Cutter (A64047)
Bobcat 60�...
2016 Ford F-350 Pickup Truck (A62613)
2016 Ford F-350...
2019 FORD F-250 SUPER DUTY (A65643)
2019 FORD F-250...
Ford 8600 (A64127)
Ford 8600 (A64127)
Doo Little XTM-8418 Trailer (A66285)
Doo Little...
