E Hydro oil Question
/ E Hydro oil Question #1
Kubota 2350
Platinum Member
Michigan, In The Thumb
2016 JD 3046R Cab ...................... Mower: 2016 Scag Tiger Cat II ZTM
I have a JD 4310 E Hydro and I'm getting ready to change the trans oil, the dealer sold me Hy-Gard low vis for year around use.
After looking in the manual I see that this oil is only recommenced for up to 80 degrees.
Is this right? I can use just plain Hy-Gard, but not sure about winter use.
What do you guy's use that have hot and cold weather?
I use the tractor for snow removal in winter, and brush hog, and tiller in the summer.
Kind of at a loss here.
/ E Hydro oil Question #2
Lo-Vis is the correct stuff.
Dunno where you got your info for 80 degrees but this is what I found from Deere:
/ E Hydro oil Question #3
For the reason Dave points out I use low viscosity year round. There is a small, probably unworthy of mentioning but noticable performance difference: the FEL bucket when full of heavy material tends to "flop" empty on hot days with low-vis compared to hi-vis. But it doesn't take very long to develop a feel for it and compensate.
/ E Hydro oil Question #4
And to be fair and balanced, at -20F during the winter the tractor moves much more readily with low-vis!
/ E Hydro oil Question #5
Down here in North Carolina, my dealer buys much more hy-gard than low viscosity hy-gard. I run the low-vis in my JD318 garden tractor because I use it for snow removal. When I change out the hydro oil in my JD4520 CUT, I'll switch to plain 'ol hy-gard. Due to volumes, dealer has better price and machine is primarily for mowing and will see little winter use when it's below freezing.
If I was back in New England, I would run lo-vis. So like many such oil decisions, it's "where are you" and "what are you doing".
Pete
Could you define "flop" for me please?:newhere:
/ E Hydro oil Question #7
Flop - in this usage, an intransitive verb:
1: to swing or move loosely
2: to change or turn suddenly
With hi-vis, dumping the bucket either heavily or lightly loaded resulted in the same steady, predictable, uniform movement.
With lo-vis, on hot days and with a heavy load like wet clay soil, dump acceleration was much higher and terminal velocity faster.
It was the unexpected increased acceleration that caught my attention, as I was in the middle of excavating soil from the 100ft road I was building when the changeover from hi-vis to low-vis occured. Otherwise I may not have noticed.
OK, Mine will dump very fast at the very end of the dump cycle, other than that I have no problems.
Tractor has always done that though.
Probably already has low vis in it.
Thanks
/ E Hydro oil Question #9
So what are you paying for 20liters of trans/hydraulic oil now? It was about $20 when I bought my 4300, now its over twice that, but its still the same price as straight hydraulic oil....
2003 International 4300 Flatbed Dump 571559 (A62613)
2003 International...
Concrete Cut Off Saw (A66408)
Concrete Cut Off...
2019 Toyota Mirai Sedan (A61574)
2019 Toyota Mirai...
2011 Freightliner M2 106 Chip/Dump Truck, VIN # 1FVACWDU7BDAU8870 (A65563)
2011 Freightliner...
Gasoline Concrete Mixer, Honda 8.0 Engine  (A62679)
Gasoline Concrete...
New/Unused 3-in-1 Quick Attach Frame (A65583)
New/Unused 3-in-1...
