Dump Trailer / Backhoe Conunbrum
/ Dump Trailer / Backhoe Conunbrum #21
I just realized that the page is not popping up in my earlier post I will see if I can get it right this time wagon trailer with dump bed 2000# cap. and they have a hand pump conversion for the dumping.
This was more for me at this point /forums/images/graemlins/smile.gif
Thanks. The trailer will hold 8000lbs...so that's about 4X what a pickup will hold. I like that polyethelyne dump liner /forums/images/graemlins/cool.gif
/ Dump Trailer / Backhoe Conunbrum #23
thought this adapter might work if you can understand this crappy drawing I through together
I figure if the trailer has a standard 2 in ball tongue. you could take a standard slide in put a 2 inch ball on it and weld a steel plate across the bottom, put a heavy duty U- Bolt on it and hook the U-Bolt on one of the teeth on the back-hoe and tow it away.
I admit it seems to simple to work but it just might do the job
/ Dump Trailer / Backhoe Conunbrum #24
oops that drawing was backwards Try this one
Mad,
I think the concensus is that towing a heavy trailer (7-8,000lbs) with the backhoe dipper stick is not considered a good idea. The forces on the hoe without the stabilizers down will be too great. The guys who do it currently claim it's pretty easy and the jack-knife potential is low. ALSO...I can tie into the front hydraulics and dump the trailer from the seat so I don't wear the battery down. I guess the battery is good for 12 dumps per charge.
The latest idea (I posted the same question in the General Discussion group) is that the trailer is to be pushed with a quick-attach ball for the loader. That way I can use the hoe to fill the trailer, then spin around and lock into the ball and push it to the dump location .
/ Dump Trailer / Backhoe Conunbrum #26
I've got a 12' x 6' dump trailer and I've moved a few loads of dirt, rocks, stumps etc. with it. It sounds like you will be moving over some soft uneven terrain, so trying to push it might be difficult. Even pulling a loaded trailer through the terrain you described might be more than you realize and will pound the snot out of your new dump trailer. Any chance of using your dump trailer to haul some crushed stone in to make a road over the rough areas so you can use your truck? You'll be surprised how cheap stone is when you haul it yourself, especially if you have a quarry nearby. You should be able to get 4 ton for around a $20 bill.
/ Dump Trailer / Backhoe Conunbrum #27
Jim,
If I may make a suggestion. See if the company you are buying your dump trailer from will add a second cylinder. You will get much greater lift capacity and you won't have to worry as much about the possibility of the bed twisting on you. When I bought the trailer, the owner told me this was a problem with the trailers with one cylinder. I have the same size trailer and I don't regret having the second cylinder added. It cost me $200 3 years ago and was well worth the cost.
/ Dump Trailer / Backhoe Conunbrum #28
Jim, here's the ATV Wagon made by Bosski. It was $1150. I didn't go to them, but my Google search listed some reviews re. this brand on off-road.com TBN member Scrounger writes some reviews for them, but don't know if he's familiar with this product.
Echoing some concerns above, I'd be pretty nervous trying to push 4 tons of material in a trailer over soft and bumpy terrain. Good luck with your project. Hope this info. is helpful.
/ Dump Trailer / Backhoe Conunbrum #30
Thanks Tom - those trailers look very cool. I have looked at the ATV type trailers before and wasn't really all that impressed with them. The Bosski looks more heavy duty than most of the trailers of that type I have seen.
I was sort of thinking of making something like the Bosski myself - but making it a little more heavy duty and as more of dirt hauler than anything else. I just have too many projects on my plate though so I don't really have the time for it.
/ Dump Trailer / Backhoe Conunbrum #31
Just to beat the pushing idea a little more, when you are pushing, aren't you pushing against the lock mechanism as opposed to pulling against the solid part of the hitch. I guess I would ask the dealer about it. My trailer has the single cylinder and I have occasionally have to use a jack to get it started if I put to much material up front. Maybe two cylinders would eliminate that. I have heard of a trailer frame twisting, but it was cause someone put a big rock in one front corner without trying to balance the load.
/ Dump Trailer / Backhoe Conunbrum #32
I support the used 1 ton dump theory. This past year I had to clear and fill a house site. I needed my BH to stay on so I found a 1 ton dump for sale locally in good shape with inspection sticker and road worthy I really did not have the money for another vehicle but I was able to buy this truck for $3000 ( credit card check at 0% for nine months then swapped to another for six months). I'm done with my project, I've kept the truck clean, I'm sure I can get my money back + my one years insurance and registration this spring. I looked at it more like a rental than a purchase. Keep an Eye out there are deals out there.
/ Dump Trailer / Backhoe Conunbrum #33
I posted this in gen. disc. as well but thought I would put it over here, if nothing else to get me message count up....I guess that gives me a spamming mentality which is frightening, but it will move me out of the new member category so I will do it this once.
I agree with some of the other guys. I'd go to trucktraderonline.com and look for an old working dump truck. I'm doing that right now in my area and there are a couple of them.
Here's a good example.
http://www.trucktraderonline.com/caddetail.html?/ad-cache/4/9/7/78267897.htm
Have fun,
Tim
