jwmorris
- Joined
- Oct 3, 2007
- Messages
- 1,190
Monarch is owned by another outfit now but someone there is checking for me.
Monarch is now Dynamic Jack, this is a 1 year old pump, that is on a twin ram dump trailer. The return dumps into a hole,they made in the reservoir, it leaked,because there was a cover installed on top, with no clearance. It cracked the reservoir. I will try to locate a replacement, this should work for your trailer. Here is the model number.Monarch is owned by another outfit now but someone there is checking for me.
I think the axle notch is still a weak link...
in the video it is cross sectional so you can see how its made, I would think that the torque from the ends flexing spreads the load through the hole axle which I would think would twist or distort at the notch, I could be wrong and maybe the weight you plan on hauling would not be enough to distort the axel. If nothing else I would box in that notch.
