Driveway sinking
/ Driveway sinking #61
Many roads are made of well compacted clay covered with asphalt to keep water off.
In 2010 I worked a project refurbishing a WW2 airport that was now servicing 727. All of the taxiways were exactly as you described, asphalt layed directly on clay. Built for B-17 sized aircraft, 60 years later the heavier aircraft were starting to break up the asphalt.
/ Driveway sinking #62
Clay is a general term used to describe a variety of soil types, including clay, but also other materials. Hardpan is another generic term used to describe what the next layer of soil under the top layer. Soils are always in layers, the deeper down you go, the more you find.
Here, red clay is the most common building material. It's fantastic for ponds and dams because once it's compacted, it's water proof. This works great for roads if you build up the road higher then the surrounding land round it. Rain lands on the road, flows off of the road, into the ditch, and then away. If the ditches have good slope to them, and they are compacted, they dry out quickly and remain solid. If there isn't any slope, the longer the water remains sitting, the softer the soil gets, but there is a limit to how far down that moisture will go. Usually it will just sit until it evaporates.
With roads, and dealing with wet areas, it's because the water didn't have anywhere to go, and it's been sitting in that one spot for so long that it's soaked into the soil, creating a soft area. This soft area needs to be removed down to solid, or dry soil. Usually you can mix that wet, or soft soil with clean dry soil and put it back into the hole. Compact it and build it up higher to create a crown. If compacted properly, water will run off of the soil and you will never have a problem again. Road grade gravel can then be used on top of this compacted soil.
It really is this simple.
2010 Ford Crown Vic (A62679)
2010 Ford Crown...
2004 Gradall XL3100 Highway Speed Wheeled Excavator (A64194)
2004 Gradall...
24in. Terex Excavator Bucket with Teeth (A64194)
24in. Terex...
2018 Regal 29OBX 29ft Boat with 34ft T/A Boat Trailer (A61569)
2018 Regal 29OBX...
New/Unused Landhonor Mini Grapple Bucket (A65583)
New/Unused...
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
