Driveway build
/ Driveway build #1
Adrianfire509
Adrian, mo
Mahindra 1526
This is the start of the driveway for our new house build. I'm using my Mahindra Max 26 and a 5' box blade.
/ Driveway build #4
That looks great. How much top soil do you have to remove before you hit sand or clay? I had to go down 11"-13" for 600'. I brought in 170 ton of in 1-3" crusher run for a 7-8" base. I'll top it with 6" of millings next year.
/ Driveway build #6
In our area "millings" are asphalt milling - the old asphalt they grind off the road when they resurface them.
/ Driveway build #7
Millings when exposed to hot sun will re-bind and give U a 'near asphalt' drive, not like true asphalt bet great for a private drive.
On slopes , unlike crushed stone, millings don't wash away being kinda glued together.
For a top notch job a roller compactor is the way to go.
Good news is re-cycled or millings is cheaper to buy than crushed.
I did my hilly drive 20 years ago with re-cycles and it still works for me although it has many cracks in it now, the main thing being that I never need to grade as I did with gravel.
/ Driveway build #8
Curves look nice, but some people can not back up. Friend did his drive with a double barreled pan. Cut down 15-16 inches and ran 5-6 inches of #2 rock. City was doing new streets so he got mills for free.{short haul for the contractor} He was using the pan to dig a pond and ran down his new drive when the bowl was full. Some people just have dumb luck.
/ Driveway build #10
Recycle asphalt just don't look in a country drive.
Yep, needs grass growing in the middle & a few mud holes:D Our drive is around 150' long with a wider parking area to park 3 vehicles across. I'm debating on millings or crush & run as it's called in these part's.
It's been 20 years since i last put gravel on & it's really thinned out some on the slightly sloped part.
Ronnie
/ Driveway build #11
I have to spay grass and weed killer on my drive! I'm just going to buy A land lever to scrap it level. My drive is 1/4 miles it's really not to bad it's just low in spots.
/ Driveway build
It varies but for the most part I only have to go 8"-10" to hit clay.
New/Unused Wolverine 6 Way Dozer Blade (A65583)
New/Unused...
Massey Ferguson 10 Square Baler (A65640)
Massey Ferguson 10...
RHINO 127 - 7' OFFSET DISC HARROW (A64277)
RHINO 127 - 7'...
AUCTION STARTS HERE @ 9AM (A65053)
AUCTION STARTS...
2012 UTILITY VS2RA 53X102 REFRIGERATED TRAILER (A59914)
2012 UTILITY VS2RA...
2021 John Deere 4044M (A64126)
2021 John Deere...
