driveway back blade.
/ driveway back blade. #21
I am starting to wonder if weight might be an answer to helping me get work done with the blade.
Easy answer is: YES!
I had 5' back blade that I'd picked up in a package purchase (was after a nice box blade- 5') and found that unless you're spreading loose stuff it was pretty much useless (and it was, as non-hydraulic ones go, a higher end unit). Contrast this to my 1,200 lb box blade on my NX and I can scrape the heck out of just about any surface (was at the neighbor's a while back and he was doubting that I'd be able to scrape a section of his driveway; not only yes, but I was also able to quite readily pop out some embedded concrete, which he was happy to have done). I don't have a hydraulic tilt, but for my uses I don't really need one (couldn't justify it); I'd think that with a back blade it would likely be a must-have. Best leveling that I've been able to do (though it's a box blade it's really all that different than a back blade as far as the physics of things go) works best pushing (going in reverse); as airbistcuit recommends, I suppose that a gauge wheel would make a lot of difference (going in reverse gets a bit old after a while!).
UNUSED WOLVERINE HYD TILLER (A64281)
UNUSED WOLVERINE...
Timpte 720 All Aluminum 7000 Tilt Trailer (A63689)
Timpte 720 All...
UNUSED WOLVERINE HYD MINI AUGER (A64281)
UNUSED WOLVERINE...
2014 Dodge Journey SUV (A61574)
2014 Dodge Journey...
2004 International 4400 Flatbed-Dump (A62613)
2004 International...
2008 MACK CHU613 DUMP TRUCK (A63569)
2008 MACK CHU613...
