Drawbars
/ Drawbars #11
After making a draw bar stabilizer based on info from this forum, I found out that Leinbach Equipment in Winston Salem, NC (336) 924-4115 sells a stabalizer similar to the one Northern sells. Leinbach's price is $69.50 vs roughly $200 at Northern. I was going to Winston Salem tomorrow to pick up one, but we have snow in the forecast, so it may be later in the week before I get there.
The one I made does not have a 2 inch receiver, like the one on my truck. I just mounted 2 trailer hitch balls on a draw bar; then mounted the draw bar on an A frame. Welded 2 pieces of 1" square steel to the A frame to keep the draw bar from rotating. It works well, but like someone else said, you can not turn very tight. This is why I'm getting the one from Leinbach.
I priced buying a receiver and welding it to the draw bar. In the end, the price ends up being about the same: the A frame from Agri-Supply is $28.00; the draw bar is $13.00; the 2 inch receiver is around $30.00; miscellaneous bolts to put it all together are about $12.00.
/ Drawbars
Thnaks DFB and others.
Much appreciated. So I'll try it without the stabiliser but suspect I'll need one. Although it is just for my small 6x4 box trailer and I'll see what happens !!
Gee this place is great !
Cheers
/ Drawbars #13
I use one of the drawbar locks on my B7100 and it works just fine. Since there is a TSC store in the area, I purchased the lock from them...about $17-$18 range. It's simple to install and remove. Might want to check out their website or stop by a TSC if you have one in the area.
Bob Pence
/ Drawbars #16
I wonder what happens to that if you try to raise the TPH up higher?
Rob
159120 (A60430)
159120 (A60430)
2011 INTERNATIONAL 4400 (A60736)
2011 INTERNATIONAL...
2013 Chevrolet Impala Sedan (A59231)
2013 Chevrolet...
2016 Lawnhorn Utility Trailer (A60352)
2016 Lawnhorn...
Zato Hydraulic Demolition Shears Excavator Attachment (A59228)
Zato Hydraulic...
2019 Ford F-150 Pickup Truck (A59230)
2019 Ford F-150...
