Drawbar question
/ Drawbar question #11
</font><font color="blue" class="small">( Why would you not have any concern about rollover when using a boom pole? )</font>
Because, as I said, I hook up to the boom pole at the same level as the drawbar. I don't hook up to the end of the boompole, I hook up where the pole comes off the 3pt. That way, I can lower the pole enough to have some lift after hooking up. If I had to use the drawbar, I'd have no lifting ability after hookup. This works great for logs. John
/ Drawbar question #12
John,
If you have the third arm connected, you are pulling from above the needed place. It is not like using a ground engaging implement, where the link is in compression. It doesn't matter very much what the position of the boom is because of that.
/ Drawbar question #13
Attached is a picture of a TSC drawbar, with a top link made to keep it from rotating. Hiding behind it, behind the lower right of the triangle formed by the greenery, is the actual factory drawbar. On my JD 4010, the factory drawbar has 2 holes to attach things. Only problem is they're to/fro holes. On the TSC drawbar, I can leave my ball for my Gravely cart in the middle and attach other "Y" hitch stuff to the side or raise and attach to the factory drawbar.
Ralph
/ Drawbar question #14
</font><font color="blue" class="small">( John,
If you have the third arm connected, you are pulling from above the needed place. It is not like using a ground engaging implement, where the link is in compression. It doesn't matter very much what the position of the boom is because of that. )</font>
In theory you may be right, but I've had absolutely no front end lifting doing it this way. If I raise the boompole above the level of the drawbar, I do have a lighter front end. In any event, I go very slowly when pulling anything, and the object is usually only a couple of inches off the ground. John
/ Drawbar question #15
LostnTractorlnd
We all got busy answering your questions and forgot our manners. /forums/images/graemlins/blush.gif
Welcome to TBN. /forums/images/graemlins/smile.gif
I'm sure our answers are why you’re asking. Both are drawbars. The correct one to use for pulling is the one mounted to tractor frame, not the 3PH lift arms.
/ Drawbar question #17
What I did with my drawbar is weld a 2 inch reciever onto it with a chainhook on either side. That way I can use my different size balls or just a flat if needed, or just a chain or two, sure makes it a lot handier. Also a great place to grab for a tiedown when on the trailer.
/ Drawbar question #18
A boom pole is a BIG lever. With a long enough lever and fulcrum you can move the earth. Be careful out there.
/ Drawbar question #19
</font><font color="blue" class="small">( The correct one to use for pulling is the one mounted to tractor frame, not the 3PH lift arms.
)</font>
Keep in mind that not all tractors have the swinging drawbar.. and that a proper drawbar stay setup, used with a 3pt drawbar can be just as 'correct' for pulling, within reason.. etc.
Soundguy
/ Drawbar question #20
Your are right. I forgot about many of the older Fords and similar tractors required a add on for the draw-bar. My Farmall 340 did not have one either.
The important thing to remember is the limitations and proper setup of any of the draw-bars used.
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2021 Chevrolet...
2005 DRAGON ROLL-OFF  TRAILER (A60736)
2005 DRAGON...
2016 Bobcat T650 (A60462)
2016 Bobcat T650...
2006 CATERPILLAR 320CL EXCAVATOR (A59823)
2006 CATERPILLAR...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
2019 FREIGHTLINER WATER TRUCK (A58214)
2019 FREIGHTLINER...
