Draw Bar
/ Draw Bar #1
Joe_W
Greenville, Ohio
2001 Kubota B2910
Has anyone set up a 3PH drawbar to tow with? I am considering mounting one of these to my 3PH, (the one that is a flat bar in the middle 3/4 with holes drilled across it, and round bars on the ends to slip into the 3PH), attaching a hitch ball to the middle and using it to tow a dump trailer with. My concern is that the drawbar will rotate back and forth as I start out and stop, wearing out or breaking the ball or the hitch on the trailer. I know that putting a regular reciever type hitch on the 3PH is a better idea, but I am looking to save afew bucks. I was wondering if this would work or not. Thanks for your replies.
Joe W.
/ Draw Bar #2
Joe,
We had this discussion through the "meat grinder".../w3tcompact/icons/wink.gif
Check out this past discussion for all the above...
Under carriage & 3-Pt Drawbar Hitch
And don't forget to order one of these drawbar lock bargains for $12...
/ Draw Bar #3
There are some very simple brackets that you can use to prevent the bar from rotating. Think they are pretty cheap. They have been discussed on here somewhere before....you may want to search to see if you can find the whole discussion.
For a photo of the drawbar lock kit you can check out this link.
Kevin
/ Draw Bar #4
John, apparently you are a faster typer than I am....or better at searching for old links!!! /w3tcompact/icons/wink.gif/w3tcompact/icons/smile.gif
Kevin
/ Draw Bar #6
Whew, you guys are on the ball this morning. I just sent him to some of your information, Kevin./w3tcompact/icons/laugh.gif
Bird
/ Draw Bar #7
Bird
Old age must setting in./w3tcompact/icons/frown.gif I don't even remember the tread./w3tcompact/icons/blush.gif I've been looking for brackets like that./w3tcompact/icons/smile.gif
/ Draw Bar #8
Kevin,
Probably just lucky... /w3tcompact/icons/smile.gif
Ask Glennmac, one day he asked for a "picture" of Big Bud... that took a few minutes.../w3tcompact/icons/blush.gif... then I gave him two! /w3tcompact/icons/wink.gif
I only wish I could get my work done around here that fast.../w3tcompact/icons/laugh.gif
/ Draw Bar #9
Ron, don't feel bad; took me awhile to look it up. And probably the only reason I remembered it was because several years ago I didn't know about those locks or I would have bought one, but instead I made the contraption in the attached photo so I still use it.
Bird
/ Draw Bar
Boy, you guys are good, and quick too. I just looked and found one of the drawbar locks in a TSC catalog, but it was $29.95. Where do they sell the ones for $12? Thanks a lot everyone, I really appreciate it.
Joe W.
/ Draw Bar #12
Joe,
If you can't buy this locally at TSC or Quality Farm, you can call SpeeCo customer service at 1-800-525-8322, ask for Kelli and they will send direct {must be prepaid}.
I believe the price now is about $20. plus 5 or 6 shipping. {you only need one to lock the bar in place}
/ Draw Bar #13
Bird
You should put some <font color=orange>orange</font color=orange> paint on it before John puts some <font color=green>green</font color=green> on it./w3tcompact/icons/laugh.gif
/ Draw Bar #14
Shucks, Ron, it ain't time to paint it yet; I've only been puttin' it off for 5 or 6 years./w3tcompact/icons/wink.gif
Bird
/ Draw Bar #15
Joe,
I made something using a spare top link. Just bent some 12mm (1/2 inch) threaded rod thru the spare end of the top link, and down into the 2 end holes of the drawbar.
Works better than the the bracket idea because I can tip the trailer back and the ball remains vertical.
Hope this helps.
Cheers
Neil R.
PORTA POTTY (A67714)
KOMATSU PC88MR-11 EXCAVATOR (A64279)
KOMATSU PC88MR-11...
2019 JOHN DEERE XUV855M S4 CART (A66091)
2019 JOHN DEERE...
2006 Mercury 115ELPTO 115hp Outboard Boat Motor. (A66738)
2006 Mercury...
2017 Toyota Tacoma 4x4 Ext. Cab Pickup Truck (A66736)
2017 Toyota Tacoma...
20 FOOT SHIPPING CONTAINER WITH CONTENTS (A68842)
20 FOOT SHIPPING...
