3-Point Hitch Draw bar swing
/ Draw bar swing #1
branman1971
Texas
Yanmar YM1700
How can I keep my drawbar from swinging side to side? I started to build a triangle shaped part like I have seen but I don't think it will help. Are my chains too long maybe???
/ Draw bar swing #2
For test purposes X the chains and see if it slows the swing down to a dull roar.
/ Draw bar swing
I don think they are long enough to cross...
/ Draw bar swing #5
Simply tighten the turnbuckles to get out all the slack.
My neighbor, an experienced third-generation farmer, advised me to tighten even more until there is no side to side motion at the implement at all. (I don't run that tight.)
Edit:
I am thinking of cutting a link out of the chain...seems like that might work.
Oops I just saw that. Cutting a link will be difficult, or rather, reassembling it afterward will be difficult. Is that an aftermarket chain set? The chains are apparently too long.
/ Draw bar swing #6
I'd probably modify them to include an adjustable turnbuckle to take up the slack.
/ Draw bar swing #7
Is there a turnbuckle to adjust the length? Most I've seen are mounted on the axle housing. Can you move them there and reduce the motion?
Depending on what you're pulling you want some movement. If an implement hits something and can deflect it might prevent damage.
/ Draw bar swing
Turnbuckles are all the way in. I think if i cut one link it will fit snug and then i can loosen buckles to have some give...but right now the arms almost touch the tires...
/ Draw bar swing #9
The staychains on the rear axle housings have built-in turnbuckles. Yours look loose....can't you tighten them?
/ Draw bar swing #10
Another suggestion: See the bolt that goes through the bottom of the axle and provides an attachment point for the sway chains? I wonder if you could swap those parts around so that bolt goes through in the opposite direction, starting from the outer side, and the link secured by that bolt is farther out.
That might use up some of the unwanted length of the sway chains.
/ Draw bar swing #11
Do your staychains attach to the axle housing with a shackle? It'll be easy to reattach 'em if they have a shackle. If not, you could buy and use a shackle after you take a link out of the chain........
Good luck!!!
/ Draw bar swing #12
Trouble with that is, the chain links are too fat to slip a shackle into. When they build those they apparently weld each link, and the shackle ends, after assembling them.
It seems to me that shortening the set by one link would require sawingoff/rewelding one eye of each shackle.
/ Draw bar swing #13
Buy a smaller/thinner shackle?
/ Draw bar swing
I could try to swap the chain mount to the outside of the axle hub. That's smart, but there is lots of slack.
/ Draw bar swing
Oh, and I got shackles on both sides...
/ Draw bar swing #16
Change the pins on the implement to the inside.
Worked for me.
YM2000 with Boxblade, Phd, 48" Bush hog all Pins inside. Snugs up good. No side to side movement on any of them.
Subsoiler, Can not put pins inside without major mods. That one still sloppy.
/ Draw bar swing #19
You could cut them, and simply bolt right through the links. OR......
3 Point Hitch Stay Chain- Yanmar & JOHN DEERE Tractor
You could just buy these. I broke one of mine off last week, just put a new one on today....
(whoops, I see my link didn't work. on eBay, just search Yanmar tractors)
/ Draw bar swing
Worked for me.
looked at this too but puts turnbuckle in bad angle for adjustment and makes it way too short.
2005 JOHN DEERE 310G BACKHOE (A65053)
2005 JOHN DEERE...
2012 STEPHENS CRUDE PUP TRAILER (A67714)
2012 STEPHENS...
PALLET OF FLANGES (A68842)
PALLET OF FLANGES...
Metaltech Climb and Go (A64553)
Metaltech Climb...
23.1-26 Tires - Set of 2 (A68134)
23.1-26 Tires -...
Unused 2021 Paladin QH1 3 Point Quick Hitch Tractor Attachment (A66734)
Unused 2021...
