Draining air compressor
/ Draining air compressor #21
Thanks.... I will contact the manufacturer and see what they have to say. Thanks........ Junk...
/ Draining air compressor #22
Junk I'm a betting man. I say the unloader is that device sitting on top of the cylinder head and the line going up to it is what you are looking for. They do make 1/4 inch compression couplings if I'm wrong...... /forums/images/graemlins/grin.gif
/ Draining air compressor #23
What PSI are you guys running? I was getting ready to place an order for a new compressor for Dad and was going to order one of the auto drains for me and my lowly Craftsman, but I typcially run it at 145 PSI with an oulet PSI of 90 - 120 depending on what I'm running. Harbor Freight's website says that it is only good for 100 PSI. I can't believe you guys are only running 100 PSI though.
PS Don't get me started on how bad the Harbor Freight stores - or at least their help is. Makes Lowes look like 5 star restaurant. /forums/images/graemlins/grin.gif
/ Draining air compressor #24
My compressor is 150 psi shutoff and I run at 90 psi after the regulator. My HF auto drain works with no problem but I did change the plastic tube to 1/4" copper tubing using new correct fittings.
/ Draining air compressor #25
To cut down on the noise I put a small air compressor in my attic suspended from the rafters.
Ran 1/4" drain hose out the bottom of the tank, through the ceiling, down the wall to the floor where I have a pitcock valve.
TBAR
I was also unsuccessful finding one that was rated for over 100psi and I run 150psi in my tank. So I chickened out and went with the ball valve vented to the outside. Works fine.
/ Draining air compressor #27
More than a few of us are using the auto-valves at pressures higher than they were rated for. I haven't had a minutes problem with mine since I installed it.
I guess this also means that I'll be visited by the TBN security safety enforcement team. Man I hope those guys ain't too big. /forums/images/graemlins/tongue.gif
2013 POLAR TANK 8,500 GAL ALUMINUM TRAILER (A60736)
2013 POLAR TANK...
Kubota ZG222 (A60462)
2024 GREAT DANE FREEDOM LT FLATBED TRAILER (A59823)
2024 GREAT DANE...
207276 (A52708)
207276 (A52708)
BOMAG BW213 SMOOTH DRUM ROLLER (A58214)
BOMAG BW213 SMOOTH...
2017 JOHN DEERE 350GLC EXCAVATOR (A62129)
2017 JOHN DEERE...
