Draining air compressor
/ Draining air compressor #21
Thanks.... I will contact the manufacturer and see what they have to say. Thanks........ Junk...
/ Draining air compressor #22
Junk I'm a betting man. I say the unloader is that device sitting on top of the cylinder head and the line going up to it is what you are looking for. They do make 1/4 inch compression couplings if I'm wrong...... /forums/images/graemlins/grin.gif
/ Draining air compressor #23
What PSI are you guys running? I was getting ready to place an order for a new compressor for Dad and was going to order one of the auto drains for me and my lowly Craftsman, but I typcially run it at 145 PSI with an oulet PSI of 90 - 120 depending on what I'm running. Harbor Freight's website says that it is only good for 100 PSI. I can't believe you guys are only running 100 PSI though.
PS Don't get me started on how bad the Harbor Freight stores - or at least their help is. Makes Lowes look like 5 star restaurant. /forums/images/graemlins/grin.gif
/ Draining air compressor #24
My compressor is 150 psi shutoff and I run at 90 psi after the regulator. My HF auto drain works with no problem but I did change the plastic tube to 1/4" copper tubing using new correct fittings.
/ Draining air compressor #25
To cut down on the noise I put a small air compressor in my attic suspended from the rafters.
Ran 1/4" drain hose out the bottom of the tank, through the ceiling, down the wall to the floor where I have a pitcock valve.
TBAR
I was also unsuccessful finding one that was rated for over 100psi and I run 150psi in my tank. So I chickened out and went with the ball valve vented to the outside. Works fine.
/ Draining air compressor #27
More than a few of us are using the auto-valves at pressures higher than they were rated for. I haven't had a minutes problem with mine since I installed it.
I guess this also means that I'll be visited by the TBN security safety enforcement team. Man I hope those guys ain't too big. /forums/images/graemlins/tongue.gif
2021 CAM P4EC16  16ft 8000lb Trailer w/ Ramps (A64047)
2021 CAM P4EC16...
2015 GENIE S-65 MAN LIFT (A63569)
2015 GENIE S-65...
Kubota M4700 (A60462)
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
2019 KOMATSU WA320-8 WHEEL LOADER (A64279)
2019 KOMATSU...
2019 ISUZU NPR 4X2 S/A 20FT BOX TRUCK (A59910)
2019 ISUZU NPR 4X2...
