Draft Control? When? How? Why?
/ Draft Control? When? How? Why? #21
A top and tilt replaces the toplink and adjustable side link with hydraulic cylinders. As long as you have hydraulic outlets to hook them up to, you can install them.
Who sells these, and what do they run?
Thanks.
/ Draft Control? When? How? Why? #23
Sorry to barge in . But I'm pretty much set on a Kioti dk35.
it list it's 3ph control as position ,draft ,and I believe,
mixed . I understand the first two, what is mixed ????
Thanks , John
/ Draft Control? When? How? Why? #24
You have two handles, one for position and one for draft. Mixed is when you use the position control to set the range of motion and then the draft to set the sensitivity. When you use the draft control alone the three point goes all the way down, you might not want to completely bury the implement but still have the draft function.
Ford Pickup Truck Bed (A59230)
Ford Pickup Truck...
2018 Peterbilt 320 EZ Pack 40yd Front Loader Garbage Truck (A59230)
2018 Peterbilt 320...
2020 Hino Garbage Truck (A60352)
2020 Hino Garbage...
2013 Nissan Sentra Sedan (A59231)
2013 Nissan Sentra...
2012 COMPTANK ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK ACID...
CASE SV280 SKID STEER (A62129)
CASE SV280 SKID...
