Draft Control? When? How? Why?
/ Draft Control? When? How? Why? #21
A top and tilt replaces the toplink and adjustable side link with hydraulic cylinders. As long as you have hydraulic outlets to hook them up to, you can install them.
Who sells these, and what do they run?
Thanks.
/ Draft Control? When? How? Why? #23
Sorry to barge in . But I'm pretty much set on a Kioti dk35.
it list it's 3ph control as position ,draft ,and I believe,
mixed . I understand the first two, what is mixed ????
Thanks , John
/ Draft Control? When? How? Why? #24
You have two handles, one for position and one for draft. Mixed is when you use the position control to set the range of motion and then the draft to set the sensitivity. When you use the draft control alone the three point goes all the way down, you might not want to completely bury the implement but still have the draft function.
2011 Ford F-550 Truck 4x4 (A62613)
2011 Ford F-550...
2014 International PayStar 5900i T/A 24ft Flatbed Truck (A64194)
2014 International...
2009 CHEVROLET 3500HD 4x4 PICKUP TRUCK (A59912)
2009 CHEVROLET...
Stryker 1.5 yard Slide in Spreader Box  (A62679)
Stryker 1.5 yard...
Stout Brush Grapple XHD84-6 (A66285)
Stout Brush...
60ft. Truck Auger (A65640)
60ft. Truck Auger...
