Draft Control? When? How? Why?
/ Draft Control? When? How? Why? #21
A top and tilt replaces the toplink and adjustable side link with hydraulic cylinders. As long as you have hydraulic outlets to hook them up to, you can install them.
Who sells these, and what do they run?
Thanks.
/ Draft Control? When? How? Why? #23
Sorry to barge in . But I'm pretty much set on a Kioti dk35.
it list it's 3ph control as position ,draft ,and I believe,
mixed . I understand the first two, what is mixed ????
Thanks , John
/ Draft Control? When? How? Why? #24
You have two handles, one for position and one for draft. Mixed is when you use the position control to set the range of motion and then the draft to set the sensitivity. When you use the draft control alone the three point goes all the way down, you might not want to completely bury the implement but still have the draft function.
2015 Ford F-450 4x4 Crew Cab Landscape Dump Truck (A64556)
2015 Ford F-450...
2023 CHEVROLET 3500HD TRUCK (A63276)
2023 CHEVROLET...
Aluminum Bell (A65583)
UNUSED 2023 JCB S3246E ELECTRIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
2023 Ford F-350 4x4 Flatbed Truck, VIN # 1FTRF3DM5PEC15665 (A65563)
2023 Ford F-350...
(2) 10ft Nesting Boxes (A65579)
(2) 10ft Nesting...
