DPF Regeneration driving me crazy...
   / DPF Regeneration driving me crazy...
Your not doing something correct. My l3901 has 1 regen in 124 hours
I drove my JD 790 yesterday after I got my hydraulic cylinders back, and noticed something. I never take it off idle, unless I take it on the road, or need to lift a huge object. I must uncounciously be doing the same on the L3301...
^ The whole problem in a nutshell.
I wouldn't even do that to my 60 year old John Deere diesel. Not good for it!
I know my Toyota Tacoma manual says not to leave on idle, but why is my question, does something melt or overheat..?
   / DPF Regeneration driving me crazy... #94
Are we talking gas or diesel engines? Tacoma, I presume gas. Even gas engines do not reach expected performance at idle and probably become prone to fouled plugs if idled for extended periods regularly.
   / DPF Regeneration driving me crazy... #95
My diesel VW Golf regenerates, it smells like a tire fire. Honestly the first time, at a Home Depot parking lot, when it was new, I thought I had burned off the alternator belt! So, once I understood, okay, I can live with it - except that the car goes in the garage every night. I pulled in in once, smelled the tire fire, and pulled it right back out to sit in the cold overnight! I wish that the instrument panel gave me a message saying: "You really don't want the car in the garage for the next XX minutes, while it makes a stink!". Yesterday, after a day of driving, I stopped at my daughter's first... sure enough, regenerating. Have at it, you're outside anyway! A good excuse to stay for dinner, as if I needed one anyway!
My VW Passat had a light on the dash during regeneration.
   / DPF Regeneration driving me crazy... #96
I think thats whats happening, I am trying to drive it like my John Deere 790 with turf tires, much lighter tractor and easier to manage.
I sure liked those old 790s: steel everywhere and cast iron transmission cases and axles. I wish they still sold JDs like that.
   / DPF Regeneration driving me crazy... #97
For a diesel it's the opposite- it stays too cold.
Diesels don't have throttles to restrict air flow. They're wide open all the time. The power is varied by changing the amount of fuel only. This means that diesels are cold when they are idling. That's probably not good for a non DPF engine but it's really bad for the DPF. First off because idling produces more soot for the DPF to deal with, and second because the DPF does not get hot. It needs to reach a certain temp for regen but even when not running a regen the hotter it is the more soot it burns off even without the regen.
   / DPF Regeneration driving me crazy... #98
But if the diesel has a turbo, it needs to be idled before shutdown.
   / DPF Regeneration driving me crazy... #100
Yes the turbo need to cool down for shutdown if it was spooling hard. But the OP was asking about idling all the time.
Many modern turbo engines have after run coolant pumps specifically to cool the turbo after shutting the engine down so you don't need to let it idle.
2019 BOBCAT T870 SKID STEER (A60429)
2019 BOBCAT T870...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
5-6 YD BLUE LINE GRIZZLY SCREENER (A58214)
5-6 YD BLUE LINE...
2019 Land Rover Range Rover Sport AWD SUV (A55853)
2019 Land Rover...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
