double rears
/ double rears #1
fsteyer
Vermont
Mitsubishi D2000
Hi -
I have a Mitsubishi D2000. I'm thinking about doubling up my rear tires. Will I need a new axle or can the additional rim be mounted to the weight brackets of my original rim.
thanks
/ double rears
Hi -
thanks
/ double rears #3
If you don't have 2 piece wheels you will need a spacer between the wheels . I intend to do this with mt Hinomoto E264. It has 2 piece adjustable wheels so all I have to do is located another set.
Eugene
/ double rears #4
Eugene
/ double rears
thanks ..
so I need actual tandem rims?
/ double rears
thanks ..
/ double rears #7
No, but if you have welded wheel centers the tires won't have any clearance between them and the wheels won't meet.
Eugene
/ double rears #8
Eugene
/ double rears #9
It is possible (in Norway) to buy (or make) special bolts for the rear wheels. Extension bolts. They lool like long nuts with a bolt in the end. Remove the old nuts, put on extension bolts, one more wheel, and then the old nuts. This looks a bit fragile? but works.
Another solution is to maks something bucket like to put in the wheel center, with a new set of bolts on it.
/ double rears #10
/ double rears
thank you ... by the way do you have suggestions for a website that carries them?
/ double rears
/ double rears
great link ... thanks a lot
/ double rears
/ double rears #17
Make your own, and save a couple of bucks. I took a piece of pipe and made spools by welding flanges with holes for the lug bolts. /forums/images/graemlins/wink.gif
/ double rears #18
2022 EZ-GO ELITE...
2019 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A59912)
2019 FREIGHTLINER...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A64194)
2019 Allmand...
2019 CATERPILLAR 279D SKID STEER (A65053)
2019 CATERPILLAR...
1995 Khronert 307 SS Single Comp 6,500 Gallon Insulated T/A Chemical Tanker Trailer (A64194)
1995 Khronert 307...
2016 Dodge Charger Sedan (A64557)
2016 Dodge Charger...
