double rears
/ double rears #1
fsteyer
Vermont
Mitsubishi D2000
Hi -
I have a Mitsubishi D2000. I'm thinking about doubling up my rear tires. Will I need a new axle or can the additional rim be mounted to the weight brackets of my original rim.
thanks
/ double rears
Hi -
thanks
/ double rears #3
If you don't have 2 piece wheels you will need a spacer between the wheels . I intend to do this with mt Hinomoto E264. It has 2 piece adjustable wheels so all I have to do is located another set.
Eugene
/ double rears #4
Eugene
/ double rears
thanks ..
so I need actual tandem rims?
/ double rears
thanks ..
/ double rears #7
No, but if you have welded wheel centers the tires won't have any clearance between them and the wheels won't meet.
Eugene
/ double rears #8
Eugene
/ double rears #9
It is possible (in Norway) to buy (or make) special bolts for the rear wheels. Extension bolts. They lool like long nuts with a bolt in the end. Remove the old nuts, put on extension bolts, one more wheel, and then the old nuts. This looks a bit fragile? but works.
Another solution is to maks something bucket like to put in the wheel center, with a new set of bolts on it.
/ double rears #10
/ double rears
thank you ... by the way do you have suggestions for a website that carries them?
/ double rears
/ double rears
great link ... thanks a lot
/ double rears
/ double rears #17
Make your own, and save a couple of bucks. I took a piece of pipe and made spools by welding flanges with holes for the lug bolts. /forums/images/graemlins/wink.gif
/ double rears #18
2017 JLG G5- 18A TELEHANDLER (A59914)
2017 JLG G5- 18A...
2015 VOLVO P7110 ASPHALT PAVER (A65053)
2015 VOLVO P7110...
2002 Sterling L7500 Series VacCon V390LHA Combination Sewer Jetter Vacuum Truck (A64556)
2002 Sterling...
2023 John Deere 333G High Flow Compact Track Loader Skid Steer (A64553)
2023 John Deere...
2020 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2020 KENWORTH T680...
JOHN DEERE 8360R TRACTOR (A64278)
JOHN DEERE 8360R...
