double rears
/ double rears #1
fsteyer
Vermont
Mitsubishi D2000
Hi -
I have a Mitsubishi D2000. I'm thinking about doubling up my rear tires. Will I need a new axle or can the additional rim be mounted to the weight brackets of my original rim.
thanks
/ double rears
Hi -
thanks
/ double rears #3
If you don't have 2 piece wheels you will need a spacer between the wheels . I intend to do this with mt Hinomoto E264. It has 2 piece adjustable wheels so all I have to do is located another set.
Eugene
/ double rears #4
Eugene
/ double rears
thanks ..
so I need actual tandem rims?
/ double rears
thanks ..
/ double rears #7
No, but if you have welded wheel centers the tires won't have any clearance between them and the wheels won't meet.
Eugene
/ double rears #8
Eugene
/ double rears #9
It is possible (in Norway) to buy (or make) special bolts for the rear wheels. Extension bolts. They lool like long nuts with a bolt in the end. Remove the old nuts, put on extension bolts, one more wheel, and then the old nuts. This looks a bit fragile? but works.
Another solution is to maks something bucket like to put in the wheel center, with a new set of bolts on it.
/ double rears #10
/ double rears
thank you ... by the way do you have suggestions for a website that carries them?
/ double rears
/ double rears
great link ... thanks a lot
/ double rears
/ double rears #17
Make your own, and save a couple of bucks. I took a piece of pipe and made spools by welding flanges with holes for the lug bolts. /forums/images/graemlins/wink.gif
/ double rears #18
JCB 3TS-8T TELESKID (A65053)
JCB 3TS-8T...
Man Basket Forklift Attachment (A64553)
Man Basket...
2004 CATERPILLAR D6R XL CRAWLER DOZER (A65053)
2004 CATERPILLAR...
2018 Ram 1500 4x4 Crew Cab Pickup Truck (A64556)
2018 Ram 1500 4x4...
2001 Ford Explorer Sport SUV (A64557)
2001 Ford Explorer...
SCAG TIGER MOWER (A64557)
SCAG TIGER MOWER...
