Does it matter which direction the pins face?
/ Does it matter which direction the pins face? #1
MikeFLA
Central Florida
Kubota B7500
On an implement, does it matter which direction the pins that are inserted into the lower links are facing? (In or Out)
It seems to me it is easier to attach and remove implements with pins facing in.
My dirt scoop is set up that way, my box blade and RMM are not. Any thoughts?
/ Does it matter which direction the pins face? #2
Facing out is better for side-to-side stability, but a 30" dirt scoop is a little too wide for the old standard 26" category 1 spacing unless the pins face inwards.
/ Does it matter which direction the pins face? #3
I think it depends on which side of the lower lift arms your check chains are. If the chains and turnbuckles pull out it is easier to have the implement pins pointing out and if your check chains pull the lift arms in it is easier to have the pins pointing in. In some cases where the lift arms are close to the tires changing the pins from pointing out to pointing in can give you a little extra clearance. From an engineering stand point it may be a little stronger to have the lift arms pulled in against the implement rather than pulling out against the lynch pins but that would be a lot more trouble. It would be a real pain to have to slack off the turnbuckles each time you wanted to hook up and to have to loosen them each time you want to unhook. If this is clear as mud send me a dope slap and I will try again. I'm sure I know what I mean./w3tcompact/icons/smile.gif
Chris
/ Does it matter which direction the pins face? #4
It really depends on the implement. Generally, implement manufacturer design their products to be mounted one way or the other... But some can be mounted either way.
Additionally, some lower links (depending on tractor manufacturer) are held from swinging too far out (towards the tire)... And others are held from swinging too far in. But once mounted to an implement, it really does not matter, because one link's "swing in" is the other's "swing out"... So the implement is held from swinging too far either way (if adjusted correctly).
Remember - Most of the time a little bit of swing is a good thing... Don't tighten up the links too tight - it can add to the stresses on the links, implement and tractor.
/ Does it matter which direction the pins face? #5
Certainly not an expert on this but I do not think it matters. I turned my boxblade pins in so it would work with the BX more easily and it works fine that way on the 2410 also. I find it easier to hook up somethings that way. J
Thanks guys.
I think I am going to turn my pins in on RMM and Box Blade to see how it works. I know for a fact it will make install and remove a whole lot easier.
2008 Mercury Mariner (A62679)
2008 Mercury...
2014 Chrysler 200 Sedan (A64557)
2014 Chrysler 200...
2018 Ford Explorer SUV (A64557)
2018 Ford Explorer...
2016 KENWORTH T800 TRI-AXLE (A65643)
2016 KENWORTH T800...
2019 PITTS CONTENDER LD35-22DC RGN LOWBOY TRL (A64277)
2019 PITTS...
2018 Ford Explorer AWD SUV (A64557)
