Does Anyone Else Do This?
/ Does Anyone Else Do This? #11
Willl said:
Who's going to be checking my trailer ?
Doesn't your state require yearly inspections of your trailer?
/ Does Anyone Else Do This? #13
Disconnect the trailer electrical plug, and then pull the breakaway cable. This should set your brakes as long as the small battery lasts. With it on you probably will have a little difficulty driving away so it's sorts self reminding!:D
/ Does Anyone Else Do This? #14
If you're trying to keep the trailer from rocking more than a few inches, then pulling the lanyard on the typical electric brakes probably won't help at all.
The design of the brakes is such that when power is applied, the magnet "latches" on to the spinning wheel drum and pulls the lever arm to force the shoes out against the drum. If the wheels aren't turning then the lever sits stationary and the brake shoes are never engaged.
/ Does Anyone Else Do This? #15
Willl said:
Nope, least not yet.
Lucky you...:D
When they finally do, then you get to watch the tech throw a jack under the one side of the trailer...spin the wheels and pull the pin and see if the wheel stops...Whoopee...:D
I feel safer after every yearly inspection...:rolleyes:
/ Does Anyone Else Do This? #16
Exactly!
You guys got me to thinking about the electric brake. I never exactly thought about it but there is no way the actuator could have enough force on it own. It would have to be a situation like the magnets allow the brake to exsert there own force mechanically. But I have tried it yet to see how much play there would be. I know even with the park set hard on the truck there is still some slop in the system as the whole rig will rock back and forth a little.
/ Does Anyone Else Do This? #18
This is a bad idea.
Electric brakes (hydraulic brakes) fail off. I.e. no more battery power/juice means no more brakes.
Air brakes fail on. No more air means brakes are solidly on.
this method works fine with air brakes (and is in fact how big trucks do it)
But for electric brakes, bad idea.
If it really worries you, use chocks, cheap, work well, etc.
/ Does Anyone Else Do This? #19
I was told that in NH trailers with dual wheels rated 3500 LBS or over must be inspected yearly. I think it goes from June to June.
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59908)
2018 FREIGHTLINER...
Cat CB24B (A60462)
Cat CB24B (A60462)
UNUSED FUTRE FL-ESC220 ELECTRIC STONE CRUSHER (A52706)
UNUSED FUTRE...
Kubota L4701 (A53317)
2019 KUBOTA U35-4 EXCAVATOR (A52706)
2019 KUBOTA U35-4...
7ft Pull-Behind Rake Tractor Attachment (A59228)
7ft Pull-Behind...
