Does a 1500D have diff lock?
/ Does a 1500D have diff lock? #1
gsdavis1
Cleveland, OHIO
John Deere 855
If it does I cant see where to engage it? Can anyone shed some light on this?
/ Does a 1500D have diff lock? #2
There should be a pedal that you would depress with your right heel. It attaches to a long lever that attaches to a shaft that runs across the transmission.
Mike
I dont see any pedal like that on mine. Do you have a picture? I have a 1500D
/ Does a 1500D have diff lock? #4
Below is an internal picture of the diff lock and rear axle parts breakdown for a 1500.
Mike
/ Does a 1500D have diff lock? #5
Mine does. Lever is down by the right foot.
/ Does a 1500D have diff lock? #6
I have included a couple of pictures of a 1500 that I believe show the Diff lock pedal and the cross shaft.
Mike
My 1500D has no such pedal / lever or cross shaft. It is an early 1500D. I think it is like number 2500 made. There is no spot on the rear end for diff lock. When I had the tranny in the rebuild process, there were parts of it that differed greatly from the used 1500 transmission I bought.
I wouldnt care to bet that these things went through production changes as it went along .
Greg
/ Does a 1500D have diff lock? #10
Not quite sure it may be a 1500 tranny? I remember reading that MJ said that his has serial # 400 something on it so that is several hundred before yours and the tranny is what has the serial # on it so we know that were talking about trannies here and not just tractor peices that could be from who knows when in the production.
/ Does a 1500D have diff lock? #12
Greg,
I don't know much about the 1500 but I do know that on the 1510 the diff lock shaft enters the rear case in a recessed area that tends to get filled with dirt and trash. If it enters in a similar manner on your tractor and your diff lock shaft were sheared off it might be hard to spot. Mike (MJPetersen) posted a picture in this thread a while back that shows pretty well where the shaft enters the case on a 1510.
/ Does a 1500D have diff lock? #13
Greg,
:eek: Both ends of the shaft are exposed to an incredible amount of crud as the cross shaft travels clear through the tranny.
I found a pic of a 1700 which is very similar to the 1500 to let you see exactly where it exits the tranny.
Mike
Here are pictures of mine. No place that I can see for diff lock
Greg
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
New - Front mount rototiller
New - Front mount...
2018 GRASSHOPPER 900D MOWER (A66091)
2018 GRASSHOPPER...
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
JOHN DEERE 1730 - 6R40", 11R20" VACUUM PLANTER (A64278)
JOHN DEERE 1730 -...
2009 International 4300V 24ft. Cab and Chassis Truck (A64194)
2009 International...
