Does a 1500D have diff lock?
/ Does a 1500D have diff lock? #1
gsdavis1
Cleveland, OHIO
John Deere 855
If it does I cant see where to engage it? Can anyone shed some light on this?
/ Does a 1500D have diff lock? #2
There should be a pedal that you would depress with your right heel. It attaches to a long lever that attaches to a shaft that runs across the transmission.
Mike
I dont see any pedal like that on mine. Do you have a picture? I have a 1500D
/ Does a 1500D have diff lock? #4
Below is an internal picture of the diff lock and rear axle parts breakdown for a 1500.
Mike
/ Does a 1500D have diff lock? #5
Mine does. Lever is down by the right foot.
/ Does a 1500D have diff lock? #6
I have included a couple of pictures of a 1500 that I believe show the Diff lock pedal and the cross shaft.
Mike
My 1500D has no such pedal / lever or cross shaft. It is an early 1500D. I think it is like number 2500 made. There is no spot on the rear end for diff lock. When I had the tranny in the rebuild process, there were parts of it that differed greatly from the used 1500 transmission I bought.
I wouldnt care to bet that these things went through production changes as it went along .
Greg
/ Does a 1500D have diff lock? #10
Not quite sure it may be a 1500 tranny? I remember reading that MJ said that his has serial # 400 something on it so that is several hundred before yours and the tranny is what has the serial # on it so we know that were talking about trannies here and not just tractor peices that could be from who knows when in the production.
/ Does a 1500D have diff lock? #12
Greg,
I don't know much about the 1500 but I do know that on the 1510 the diff lock shaft enters the rear case in a recessed area that tends to get filled with dirt and trash. If it enters in a similar manner on your tractor and your diff lock shaft were sheared off it might be hard to spot. Mike (MJPetersen) posted a picture in this thread a while back that shows pretty well where the shaft enters the case on a 1510.
/ Does a 1500D have diff lock? #13
Greg,
:eek: Both ends of the shaft are exposed to an incredible amount of crud as the cross shaft travels clear through the tranny.
I found a pic of a 1700 which is very similar to the 1500 to let you see exactly where it exits the tranny.
Mike
Here are pictures of mine. No place that I can see for diff lock
Greg
2017 Chevrolet Tahoe SUV (A64194)
2017 Chevrolet...
2019 GENERAC MDG75DF4 TOWABLE GENERATOR (A63276)
2019 GENERAC...
2020 KOMATSU D65EX-18 CRAWLER DOZER (A65053)
2020 KOMATSU...
2012 INTERNATIONAL DURASTAR 4300 SBA 4X2 CHIP TRK (A63276)
2012 INTERNATIONAL...
2009 IC Corporation PB105 School Bus (A64194)
2009 IC...
2018 Kia Rio Sedan (A64557)
2018 Kia Rio Sedan...
