Do you mow at 540
/ Do you mow at 540 #21
The quality of cut is somewhat dependent on the tip speed of the blades. The tip speed is affected by the PTO rpm, the gearbox ratio, and the length of the blades. It seems as if there is no "standard" gearbox ratio, but most of the ones I've tried to measure are around 1.5 rpm of the output shaft to 1 round of the input (PTO). A 6' mower will have more tip speed than a 4' or 5' with the same ratio gearbox. I bought an off-brand 6' brush hog mower that makes the blades whistle. Unscientific measureing makes me believe it's more like 1.9 ratio. I can gear my tractor up one gear and reduce the engine rpms about 300-400 and still get a clean cut. I've said all that to say that quality of cut are dependent on much more than pto rpm.
/ Do you mow at 540 #22
PineRidge said:
I happen to catch the highlights of your post Bob and the way that I 1st interpreted it thought that you were touching up your blades with paint after each mowing. Thought to myself, "Man wish I had that kind of diligence." Then the true subject matter of what you were saying hit me. Boy did I feel foolish! :eek:
Uhhh... ya, PR, I use epoxy-based paint between mowings to prevent rust. Ya, right! :)
All seriousness aside, for brush, follow sharpening directions. For grass and light weeds, very sharp blades get excellent results. The object of the game when cutting grass and light weeds is to use the lowest RPM that yields a clean cut. The duller the blades, the higher that number will be, up to the attachment's recommended maximum.
/ Do you mow at 540 #23
PTO implements are designed to operate at greatest efficiency at rated PTO speed, i.e. 540 rpm, or 1000 rpm for (very high horsepower applications). If the operator's manual states to run at 540, then defer to the design engineers that designed the machine. In the long run, you will get greater efficiency, and often less wear on the unit.
I hear many of you asking how will I get less wear running 540 than if I run at 450. A good example of this is inside your gearbox of a mower. When running at rated speed on the PTO, you have the proper blade tip speed. This translates into kinetic energy that helps to "drive" the edge through the material being cut. If you slow down the machine, you now get slower speeds, less force, and have higher torque loads on the entire drivetrain, from the flywheel of the engine all the way to the tip of the blade.
With all this said, there are certain, very limited instances when the PTO speed should be reduced. A good example of this is a round baler, when baling very dry, short hay. Often under these conditions, the rotation of the bale causes material to "flake" off, and either drop out of the machine, or accumulate in all areas of the unit. Under these conditions, it is proper to slow the PTO to correct the problem. But guess what, in the operator's manual it describes this condition, and instructs you to slow the PTO.
If you always follow the owner's manual, you will be much better off in the long run.
/ Do you mow at 540 #24
'RTFM' is actually very good advice. However.. it seems many people are perfectly willing to plunk 10-20-30 thousand dollars down on a machine and not even get a manual.. ( or read it ).
I make that a priority when i get a new tractor.. that is.. get the owners/operators manual, -at least-.. and if possible a shop or service manual/ parts manual, if available.
Same with implements. Who wants to run a High dollar mower.. but not pay the 80$ for the manual ( in the case where the manual is not included.. or -lost- by the dealer.. etc. )
Soundguy
/ Do you mow at 540 #25
Every tractor model and/or brand is different. But in general, the RPM where 540 RPM PTO speed is achieved is USUALLY not where peak HP is achieved. Sometimes it's quite a bit different. On one of my tractors, 540 rpm's on the pto is at 1700 engine rpm. Peak HP is at 2250 engine rpm. At pto speed, hp level is (according to some old specs I have) 15% less than peak HP. That isn't uncommon. Most farm tractors I've been around will have the 540 rpm pto speed marked in some manner on the tach. Also, you'll find a "do not exceed" mark for pto use that's a tad faster and closer to peak engine hp output.
In the end, this isn't rocket science. So long as the engine pulls the mower (or whatever pto load is) and it cuts like you'd expect, it isn't all that critical what rpm you run at. However, in about every case I've seen, mower performance, as well as engine performance is better when you operate at or near manufacturers suggested levels. There are exceptions to every rule. In tough conditions, I'll run at or near that peak rpm level.
It's always been my thinking that the people that designed and built my equipment may just know more about the subject than I. When they give me a suggestion on how to operate it, I listen. Until someone or something proves that wrong, I'll stick with what got me here.
/ Do you mow at 540 #26
PineRidge said:
540 RPM PTO speed is like 2600 Tach. RPMs on our TC-40D. However I tend to run the RFM at about 2K RPM with good results.
I don't mow wet grass though.
HOH,
Im with Mike on this one, 2000 RPM on my Massey is about 450 PTO RPM and it works fine for me, Ill occasionally bog down on a steep hill in real thick grasses but usually only a couple hundred RPM.
Mower cuts great at that speed :)
/ Do you mow at 540 #27
The 540 speed is at 2500 on the tractor I have now and I very seldom ever go that high.I have a 6ft bush hog on a 50 plus pto hp tractor so I really don't have too_On all the tractors I have had I listen to the engine and make sure it isn't lugging and run anywhere from 1700 on up when bush hogging , depending on what I am cutting and what gear I am running in.If you are having trouble with heavy grass bunching up you maybe trying to cut a little to close and not giving the cut grass a way to escape , try lifting your bush hog a little higher and it should solve that problem.
/ Do you mow at 540 #28
I don't think 540 RPM is a magic number. I think it's a very general guideline. I think you must adjust accordingly instead of blindly running at a particular speed. I think the 540 RPM spec was a compromise reached by implement and tractor makers many years ago, and not much more. Modern metallurgy and design changes the whole equation. I think it's almost impossible to under work a tractor or implement. I bet you that not many implements and tractors are brought to the dealer for repairs for being under worked.
Here's proof for me: Running my tractor and my brush hog at 540, there is a lot of stuff going on under the deck. The grass is being cut, re-cut, shredded, and big balls of grass are left in my wake. My tractror is straining a little bit, and fuel usage is high. My cutter's gearbox gets quite hot. At 425, there is little noise, banging, or vibration. The blades make a nice swishing noise as they cut. Grass and weeds come out mostly whole, and lay down evenly. Fuel usage is excellent. My gearbox is very warm, but not hot. My gearbox is rated for 55hp, my PTO hp is 30. All the signs point to 425 being more efficient than 540. I don't think I'm in any danger of under working anything! YMMV, of course! :)
/ Do you mow at 540 #29
I have blue too, and I run my Maschio 72 in rear discharge finish mower around 2000 to 2100 RPM on the tach. I tried running around 2400, or until the 540 light came on, and the gear box got hot enough to force gear oil out of the vent.
Bottom line is that I run lower speeds and get just as good results. I have doubts about the accuracy of the lights, or even the tach. But I have had just as good results running slower. I think that everyone has to get familiar with their equipment and the job at hand. Do a little experimenting and what works best is usually best.
/ Do you mow at 540 #30
Just another opinion here, I rarely run at 540 pto rpm. I typically run enough throttle to keep the engine from lugging and produce decent results from whatever attachment I am using whether it is a mower, chipper, loader or backhoe. When finish mowing I typically run about 2200 rpm on the engine and a ground speed which is comfortable for both tractor and operator, I don't notice any difference in cut quality If I run up to 2600 rpm (or 540 PTO speed) but I will notice that the engine sounds like it is screaming and that fuel consumption is considerably greater running at the higher rpm especially after a full day of commercial mowing. I don't buy the 540 PTO rule or the other rule I have heard about having to run a hydro tractor at full throttle. I agree an engine needs to run at a comfortable rpm to prevent lugging and an attachment needs to operate at a certain rpm to produce good results but I feel - and this is just my opinion -that a little common sense and good old fashion listening to your tractor will dictate what rpm you should be operating at. I guess I'll let you know if my stubborn line of thinking causes any premature failures.
/ Do you mow at 540 #31
I find it absolutely astounding the number of members here who believe they're smarter than the engineers that design the equipment ! But then again, where would the repair shops be without them.......
//greg//
/ Do you mow at 540 #32
//greg//
Agreed.
Bob
/ Do you mow at 540 #33
I keep mine right on the 540 mark most of the time. If I'm into some tough stuff I'll give it just a wee bit more throttle but never, ever run below 540.
John
/ Do you mow at 540 #34
I don't think it's a matter of being smarter than the factory engineers. It's just a matter of "is MAXIMUM mower (or whatever) efficiency/power/effectiveness etc. required in every situation?" 540 may deliver all of the above, but if the grass is cutting fine at 450 and the tractor makes less noise or uses less fuel, why NOT run at 450?
FWIW, I usually mow at 1800-1900 tractor rpm. Don't know what PTO rpm that equates to, but it is quite a bit below 540. My grass just doesn't need any more than that. The tractor doesn't bog, the clippings are small and scattered, and I have probably cut 6 db from the noise level.
/ Do you mow at 540 #35
540? Rarely to almost never. Usually it's 430 to 480 PTO RPM, and it does a fine job with a less fuel/noise/wear & tear. Another good reason to run slow is that my ground is often rough and uneven and there are sometimes things hidden in the grass. I believe all of those who think 540RPM is sacred would agree there's a greater margin of error operating at lower RPM when you scalp or hit something you don't want to hit.
Part of this came from having to run old junk for years. Run it hard and it might come apart. Take it easy and there's a chance of finishing the job and maybe doing another. From that I learned that there's nothing magic about 540 RPM. Often the lower speeds do as well or better.
If it needs more RPM to do a good job, by all means, run at a higher RPM. To me the 540 mark on the tach has always been the PTO redline....if you NEED TO you can go that high, but I normally choose the lowest speed that does an acceptable job.
As for what the engineers think, well I are one. In that profession I learned that a degree (or multiple degrees) is no substitute for common sense. And it's common sense to recognize that the optimum blade speed for whacking down ash or sumac saplings could scarcely be the exact same optimum blade speed for cutting orchard grass.
FWIW
Bob
/ Do you mow at 540 #36
Might be just cuz that's how your throttle linkages were adjusted over the years. On my tractors, I still have throttle left AFTER setting the tach to PTO speed. My KAMA for example; engine RPMs to achieve 540 PTO rpms is 2250. Throttle stop is ~2600. On the rare occasion that I may bog down at 2250, I just give it a little foot throttle till the revs come back up.
Interesting though, that you consider a machine that bludgeons saplings suitable for cutting orchard grass.
//greg//
/ Do you mow at 540 #37
I spent quite a few years employed as an Engineer, have you ever worked with one? Quite a few are genuinely brilliant, others - that are great at running a calculator and passing exams, wouldn't have the slightest idea how to change the oil on a tractor but are designing hydro transmissions and writing technical specifications on how to operate one. Not trying to knock Engineers or anyones' opinion on how to operate their tractor - to each their own - If a tractor is designed to run all day at 540 PTO rpm per its specifications then it theoretically should last for many hours with the proper maintenance, me, I just don't like hearing an engine running at full throttle unless their is a load on it, again just my opinion - right, wrong or indifferent.
/ Do you mow at 540 #38
I assume everything people are stating here, whatever their bias, for the rear pto at 540 applies to mid-pto (e.g. MMM) also. Is there any reason to believe otherwise?
Now I'll ask the opposite question: Fuel consumption and noise aside, is running the RPMs slightly faster (~10%) than nominal harder on the tractor or the MMM, or realistically is there not enough difference is RPMs to truly matter on wear for either?
/ Do you mow at 540 #39
I agree.
/ Do you mow at 540 #40
I love my Brow Tree cutter. Send me a PM and I will try to send you some pictures. Sorry but I can not figure out how to post them in the text.
Mine is 5 ft wide which is perfect for the width of the 4720. I keep my Long 4 in 1 on to offset its 1600 lb weight. I have cut several 8" pine trees but stick to 6" hardwoods.
I though their gear boxes were rated for 160 Hp tractors on the 6 ft mowers?
Woodboss outside of Atlanta has a video on their site of the unit and I will locate the other site that shows some video.
One word of caution -make sure you have rear and side HD screens on the tractor and a FOPS. I have had a few 6-8 trees come down on my FOPS.
1987 INTERNATIONAL S1900 S/A BOX DUMP TRUCK (A64277)
1987 INTERNATIONAL...
New/Unused Landhonor Power Rake (A65583)
New/Unused...
2018 Peterbilt 579 (A64127)
2018 Peterbilt 579...
2017 Peterbilt 579 (A64127)
2017 Peterbilt 579...
2019 F-550 Bucket Truck (A63689)
2019 F-550 Bucket...
CHANDLER 14' LITTER SPREADER (A64277)
CHANDLER 14'...
