Do I need a 3 point quick hitch?
/ Do I need a 3 point quick hitch? #42
I have a tiller with the old open pins. They are a pain. But the two newer implements, a Woddland Mills stump chipper, and wood chipper both have the two sided parts with a pin to go through the tractor arm. Those are really easy to hook up. Not sure I rehook often enough to make a quick hitch worthwhile.
Bolt on pins aren't any older or newer than clevis style pins. Clevis style is a bit more complex & expensive, but over double the strength of the bolt on style. You can easily get the proper sleeves to make them proper Quick Hitch compatible.
While I have most of my gear setup with the sleeves/bushings, a few do not. They still work fine but are a little sloppy. I'm sure the rest of my ancient flail mower will fall apart before the hitch pins, even with them wearing a lot faster due to no bushings.
2013 CATERPILLAR 305E CR EXCAVATOR (A64279)
2013 CATERPILLAR...
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A64279)
2016 CATERPILLAR...
UNUSED WOLVERINE BUCKET (A64281)
UNUSED WOLVERINE...
Caterpillar Warranty Guides (A63117)
Caterpillar...
Altec Digger Derrick Hydraulic Boom (A61573)
Altec Digger...
Rotary Auger Motor Attachment (A61572)
Rotary Auger Motor...
