DK45 radiator questions
/ DK45 radiator questions #1
GMIslander
Canada
DK45SE HST
Is the radiator on DK45 plastic or metal tanks. Mine needs repair and wondering how to proceed.
Musta happened last thing this afternoon noticed coolant running out of small maybe 1/2" nipple on bottom right of rad.
Brush poked up in there I expect.
I'm scheming how to repair it and I this is good place to start.
To cold and dark for me to crawl in there tonight old too.
/ DK45 radiator questions #2
My Dk40SE has plastic tanks.
A few years ago I let my wife do some brush hogging unsupervised, got an alder up in the fan and wiped out every blade on the fan.
I pulled out the entire cooling pack so I could have a rad shop check things over.
It's bit of a process to pull everything out, luckily for me it happened in the summer, wouldn't want to take the job on in the winter.
/ DK45 radiator questions #3
Plastic, good luck.
/ DK45 radiator questions #4
Plastic radiator? Mines metal. The fan blades may be plastic. Not the radiator
but mines a 2010 model. Ive never seen a plastic radiator… did not know it was a thing
/ DK45 radiator questions #5
The cores yes, but have you checked the tanks?
My little Kioti has plastic tanks.
Plastic
I'll have a new one the first of the week.
I can't be without the tractor so I'll install the new one and if my repairs are successful there will be a spare.
Thanks
/ DK45 radiator questions #7
Any chance that the tanks are ABS? If so, you may be able to do a hokey job of a temporary fix by cleaning the broken part surfaces really well and using ABS drain pipe solvent to glue them back together.
I used this to repair a broken handle on a shop vacuum hose about 10 years ago, and it is still holding together.
/ DK45 radiator questions #8
The vast majority of radiators have plastic tanks at either end of the core.
/ DK45 radiator questions #9
The tanks on either end are a high temp nylon, with aluminum fins. If its in the aluminum, its so thin, its probably not fixable. If its in the 'plastic', plastic welding is possible. Rads are expensive. Mine went on a 3yr old tractor from the inside out... strangest thing...
/ DK45 radiator questions #10
And to add to that - the ABS solvent probably will not work on nylon.
Friday took the day and went to the city to pick up the new rad. When I got there I noticed the box containing the rad was a bit damaged so we unboxed it to find the top tank was all busted up. The pressure cap and plastic flange it connects to fell out on the floor. A hole about the size of a tennis ball in top tank.
That was a nine hour day shot.
Took the damaged rad out yesterday took an hour and a half, a tight fit.
I would not trust using this repaired for the long term so I hope the next new one is in one piece.
You can see the split at the bottom of the small nipple.
/ DK45 radiator questions #12
That looks like so much fun! I suggest that you call and have them unbox before you drive to the dealership on the next one. I think I will do that also when I order delicate parts.
I replaced my rear window not too long ago, and the box was in bad shape, so the dealer too a look before they called to let me know that the window had arrived.
/ DK45 radiator questions #13
I Googled "plastic radiator repair" and there are products and YouTube videos that could maybe repair that crack.if it were me, I would hang onto the broken radiator and try to repair it as a spare.
/ DK45 radiator questions #14
Another thing is see if a radiator shop can do a good repair job and then keep it as a backup to guarantee that you never have this problem again.
/ DK45 radiator questions #15
I don't know what they are hitting you for the new radiator, but I have been surprised sometimes on the cost of custom aluminum radiators. I have seen them for less then some pricey new ones.
$900 C
with ought the damage
2019 Forest River R-Pod RP-191 Travel Trailer (A61574)
2019 Forest River...
UNUSED WOLVERINE SB66 - 66" ROCK BUCKET (A64281)
UNUSED WOLVERINE...
2019 Merlo TF 42.7 (A60462)
2019 Merlo TF 42.7...
(2) UNUSED 11.2-24 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED 11.2-24...
FORD 5610 TRACTOR (A64276)
FORD 5610 TRACTOR...
New Holland 3930 (A60462)
New Holland 3930...
