DIY Tractor 4x4
/ DIY Tractor 4x4
I used the gearbox from the car, dismantle 3-4 gears, they are now not necessary
IMG_20240704_085117.jpg IMG_20240704_121735_1.jpg IMG_20240705_163901.jpg IMG_20240705_163946.jpg IMG_20240705_181635_1.jpg IMG_20240705_181642_1.jpg
/ DIY Tractor 4x4 #5
WOW... Just WOW.. Very interesting. I went to your you tube site. You are the real deal when it comes to thinking out and making the attachments we all take for granted.
The Cutter video was great, detailed but not cluttered. Can't wait to see what you make in the future.
/ DIY Tractor 4x4 #6
At the beginning of the summer I started building a garden tractor.
Another one ? When i started reading, i looked at the posting date because i remember you building a tractor some 6 to 7 years ago here on TBN
Anyways, i'll enjoy following this build too 👌😀👍
/ DIY Tractor 4x4
Shortening of the semi-axis. I didn't want to weld "butt to butt", I think this method is not reliable and the axis will break near the welding seam. I cut the axle to length, drilled the hole and pressed it in. Then drilled a hole, pressed a roller from the bearings into it as a key, and welded it in a circle. Time will show the reliability of this method.
/ DIY Tractor 4x4 #14
geometry dash wrote:
Greetings. At the beginning of the summer I started building a garden tractor. His task was to mow the lawn, the result exceeded all my expectations, so I decided to do 4x4.
Damn man, this thing is going to be better built than 95% of garden tractors 😂
5' X 8' SINGLE AXLE UTILITY TRAILER (A64280)
5' X 8' SINGLE...
213106 (A64276)
213106 (A64276)
Landhonor Mini Skid Steer (A60352)
Landhonor Mini...
UNUSED MOWER KING-AGT SAII100 (A64281)
UNUSED MOWER...
2019 Chevrolet Express 2500 Cargo Van (A61573)
2019 Chevrolet...
300 GALLON HYD OIL TANK (A64280)
300 GALLON HYD OIL...
