DIY Pushbox
/ DIY Pushbox #1
enviramental
Ottawa, Ontario, Canada
none
HI
I built this pushbox for the front of my B2320. I used old steel from a scrapyard for the sides, and three pieces of angle for the frame. The skin of the box is repurposed from the bottom of a used 200 gallon home heating oil tank. I drew a sketch on my garage floor and then in sketchup to see what it would look like. Showed it to my father who recommended I extended the mounts down to the main angle at the bottom which would double as a cutting edge. When it was all done it looked ok. Forgive the ugly welds and rough edges - I am an amateur
/ DIY Pushbox #2
Looks good from where I’m sitting. The only different to add might be a cutting edge on the top so you could roll the plow over and use that edge to back drag away from doors.
/ DIY Pushbox #3
My only recommendation is to clean,, CLEAN CLEAN the inside, then primer and paint the inside.
Where I live, snow LOVES to stick to rusty surfaces,, compared to smooth painted surfaces.
/ DIY Pushbox
My sketchup drawing has the cutting edge, I plan on adding one as soon as I can get back to the scrapyard. The inside is not painted as it is still covered in sooty(from cutting and welding) heating oil. I figured after a winter of plowing, that it would be clean and I can paint next spring. Rattle can orange for now..
/ DIY Pushbox #5
The issue is that with a box it does not get the scouring action that a plow does as the snow is not sliding across the surface. Therefor it does not see the cleaning action snow gives a blade. However with a box it really likes to pack in there. If the surface is not smooth it will be much harder to get off.
/ DIY Pushbox
I finished it off today with a cutting edge I bought at the scrapyard. It was worn, however, so I reversed it for a straight edge, then I backed with 2X1/4 inch flat bar to give more volume capacity. This also covered up the worn curve (sneaky, I know). I was thinking a sharp cutting edge really wasn't necessary. If it doesn't work well, I'll grind it next summer. I'm pretty sure the testing department will be pleased with the results and determine this is not needed ;).
The fluid film is probably a good way to go, I think I'll try that - Thanks Mr. Stan
/ DIY Pushbox #10
I finished it off today with a cutting edge I bought at the scrapyard. I'm pretty sure the testing department will be pleased with the results and determine this is not needed ;).
Looks great, my in-laws use a spray wax on their plows and blowers (fwiw) Where’s the snow to try it out?
/ DIY Pushbox
Thank you. I was walking the dog and wishing for a little snow so I could see whether it will work or not. The snow started falling about 5 mins later, but we only got a little, so the question still stands.
2014 Crane Carrier Co. Low Entry T/A Rear Loader Garbage Truck (A66736)
2014 Crane Carrier...
2011 John Deere 1200H Bunker Rake (A66734)
2011 John Deere...
JCT 72" QA Rotary Tiller (A64912)
JCT 72" QA Rotary...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
PORTA POTTY (A68842)
2017 Jeep Grand Cherokee SUV (A66738)
2017 Jeep Grand...
