DIY Carry All
/ DIY Carry All #21
Scrap metal, time and some electricity... :thumbsup: I didn't want my carryall to be tied to the tractor so much. So I made mine in two pieces, I can drop the tools off and use the tractor for other things.
Question about your toplink connection... do you have a hydraulic top link to slide into that slot?
/ DIY Carry All
no mine is not hydraulic, it has the adjustable threaded type of top link. i can drop it and have it disconnected pretty quickly, as long as it takes me to pull 3 lynch and bar pins and its off.
/ DIY Carry All #23
John Deere, if that is a belt driven tiller what do you hook it to.
It came off my Simplicity 5008 lawn tractor. I have 2 other lawn tractors just like it that it fits to as well. :thumbsup: It was just heavy enough where I figured why not use my tractor to move it? :D I would have just used the forks to pick the whole lawn tractor up but my Yanmar wouldn't do it, probably because I had the telescopic lower links on. I went and put on the originals though to run my bush hog so I will have to try again. They weigh about 350 pounds total.
/ DIY Carry All #24
Must be cause the wrong links were on it and it was out to far. Even yours should pick up 350 easy. I know my ym2000, yes its bigger, i think easily pics op 800+ lbs.
/ DIY Carry All
the finished product, i wasn't going to paint it but i had a few cans of black so i did.
i decided to use redgum planks for the base to try and keep the weight down :laughing: yeah right........ on to the next project :D
oh by the way the 3PH wont pick up a 4'x5' hay bale it just sits there. pity because it would have made life a bit easier.... oh well
/ DIY Carry All #27
I made this one for carrying my chainsaw, gas, log chains,etc. Works good, it attaches to my weight bar frame with a single pin. Easy on and off. Made from 2x2x1/4 angle and plywood bottom. Bungie cords hold the stuff on it.
/ DIY Carry All #28
Looking at your pic of the hydraulic cylinder for your carry all. How is that operated? I have thought about this and have only owned my tractor for two weeks, so all this is new to me. I like the idea.
/ DIY Carry All #29
Search for TnT or Top and Tilt or Hydraulic top link and you'll have hours for reading... Look at the thread in my signature for more details... It's really nice. I just finished leveling an area for a camper it this made it easy....
/ DIY Carry All #30
Nice work on this build !!
