Ditch Witch C99
/ Ditch Witch C99 #101
Just got off the phone with Ditch Witch. I saw that they have a bunch of tools on their web site. That includes parts and operating manuals. There is a note that says IE required. I was using IE so I asked them about it. A nice lady named Emily came on. She stepped me through adding compatibility mode to IE to access the site. It goes something like this:
-click the gear in the upper right corner
-click on Compatibility View settings
-ditchwitch.com appears in the Add this website bar
-click add
-also type in / add *ditchwitch.com
-both should now be listed
-close and reopen the browser
-Log in and you're golden!
Than I asked if she could tell me about the drive on my C 99. She transferred me to support. Nick picks up. He says, "Hmmm... that thing's about twice as old as I am." He puts me on hold for a couple minutes. Upon return he says, "You're looking at the parts manual, right?" I says, "Yep, right on your web site. Emily got me going." He tells me to look at number 7 in the exploded view, part number 115-571. In the second diagram (for later serial numbers) it is diagram number 19, same part number. He says the older guys tell him that if these springs are weak or damaged or worn it will create the symptom I asked about in the earlier post.
Moral of the story: There was basically nothing in it for Ditch Witch but all the people I spoke with there were super helpful and patient and went out of their way to take care of me. Stand up stuff!
So, every one who is looking for a Ditch Witch C99 manual, you can get it online right from them. They also tell me that many parts are still available right from them, though some have been discontinued. They are happy to help locate or will have custom manufactured that which they no longer stock.
Thanks Ditch Witch!
No, I don't work for them or have any affiliation. Just a happy customer who didn't even buy anything.
/ Ditch Witch C99 #102
Hi. I'm new to this site, but have been searching for info and manuals for my C99 for a while now. Any way I can get them from you?
Thanks.
/ Ditch Witch C99
Yes but I need an email to send them to. You can private message me if you like, and I'll get them right out.
/ Ditch Witch C99 #104
You can them them straight from Ditch Witch in .pdf format or view them on line. See the post directly above yours for how to do that.
/ Ditch Witch C99 #107
we have an older trencher, it looks like the C99, I am having trouble getting it in reverse, if anyone has the steps in doing it, please advise, have some trenching that has to be done very soon. Thanks.
/ Ditch Witch C99 #108
To access the manual for the C99 see post #101 above. You can get it right from the Ditch Witch web site.
/ Ditch Witch C99 #109
-click add
Thanks Ditch Witch!
We have friends who work at Ditch Witch; it's a class organization from what I can tell.
/ Ditch Witch C99 #110
I would be happy to help, but I will need an actual email to send attachments to. You can pm me or respond here.
I know it's late after the post but my forward and reverse thing majig is having an issue with me and I was wondering if I could get you to email me a copy of the parts list and breakdown of the c99 Digger from **** LOL? twinfreespirit@gmail.com
Any help would be greatly appreciated thank you FL Spirit
/ Ditch Witch C99 #111
You can get them directly from Ditch Witch. See post # 101 above. If you can't make that work, PM me your contact info and I will send them directly to you.
Regards
/ Ditch Witch C99 #112
hi , just aquired a c-99 ditch witch -somewhat dissassembled .i could sure use a copy of owners manual /parts book if you still have it .how much $ would you want to send me that ? thanks jim
/ Ditch Witch C99 #114
Well, let's see. I will happily send you everything I have for the price of a little good will. Private message me your contact info and I'll get it off quick-like.
~Gary
/ Ditch Witch C99 #115
Finishing up on one of the questions earlier in this thread. I was having trouble with the machine popping out of drive when in digging mode. It would rearward march a few feet, maybe only a few inches, then the reducer shifter would slowly rotate about a revolution. Then it would catch again and drive a bit, then repeat the process. After much disassembly and examination, it appeared the the locking pin of the reducer shifter was popping out of the notch in the locking plate on the frame. I reground the angles of these two parts such that there would be a positive engagement. Much to my pleasure, it now stays engaged and digs all day like it is supposed to.
I have pdfs of the manual, parts book, and engine for this thing. If you have need, let me know and I will send them off to you.
Happy trenching!
Hey Mr. Moderator, how about a forum for trenchers??
/ Ditch Witch C99
Hey guys, still out here, just not reading and posting much. I must have sent well over a hundred of the scanned manuals and parts lists out, and still do when asked and when accompanied with a private email addie.
I am truly glad there are other resources available now. As I must've said somewhere along the line, I got the hard copies from Ditch Witch in the first place. They are good people.
I don't know if a separate trencher forum would see much action but that's up to y'all. Personally I don't like when forums get super subdivided into topics because I like to see a little of everything related without deep diving.
I learned a ton here about tractoring, and still do, but mostly as a lurker. It's amazing that I could give back to anyone at all, 'cause I am a pretty small time tractor guy. But they are finally opening a TSC here about 5 miles away, and I must confess I am somewhat pumped about it.
My C99 has a fragged tire and is out behind the garage for now with no immediate missions, but I like just having it. It is on my "gotta get to it" list. It is about item 98 on the list, at least until I need it, but I am glad so many of them are still ticking.
/ Ditch Witch C99 #118
Indeed they are. We have good friends at Ditch Witch.
/ Ditch Witch C99 #119
New here to this page I also just got a ditch witch C 99 and would like a copy of operation and service parts,thank you Riceburner73
/ Ditch Witch C99 #120
2014 GULF STREAM TRAILMASTER (A65643)
2014 GULF STREAM...
2006 Hummer H3 4x4 SUV (A64557)
2006 Hummer H3 4x4...
2014 CATERPILLAR 573C FELLER BUNCHER (A64276)
2014 CATERPILLAR...
WORKSAVER 3PT / LOADER BALE SPEAR MOUNT (A64278)
WORKSAVER 3PT /...
GEN POWER 40KW GENERATOR (A64278)
GEN POWER 40KW...
2006 JOHN DEERE 700J LT CRAWLER DOZER (A65053)
2006 JOHN DEERE...
