Ditch Witch C99
/ Ditch Witch C99
I would be happy to help, but I will need an actual email to send attachments to. You can pm me or respond here.
/ Ditch Witch C99
Couple more sent out. Sorry, Dennis, did not see your request until now.
/ Ditch Witch C99 #27
Hello, I am repairing a C99 that I recently bought. A manual and parts book would be a life saver to me. I would be very appreciative if you were able to send me any documentation. izripzone@aol.com is my email.
/ Ditch Witch C99 #28
DO they still have parts for these old machines. I have one that seems to be a c99 but not quite sure yet. It has the Onan engine and you have to tie the rope on the pulley and pull till it starts. Only had it for a year and the chain that makes it run in reverse broke. Wondering if you guys know what size it could be, I'm hoping is universal or a tthe least common. I will post a pic once I find one.
JDM
/ Ditch Witch C99 #29
Dave, I would like to have a copy of the C99 manual.I have one I want to restore.
/ Ditch Witch C99 #30
Dave If you would be so kind as to send me a copy of the c99 manual I would be greatly appreciative. Thanks. My trencher is not getting spark. It has the wisconsin motor. I am currently reworking the points and condenser. hopefully that works. once again thanks for the manual. email is cfish36@hotmail.com.
Chris
/ Ditch Witch C99 #33
Hello Dave:
I am trying to purchase a C99.
I test-ran one recently, but I found the operation of the "clutch" mechanism for selecting between "forward", "reverse crawler", and "neutral" difficult and confusing.
The owner was not much help, so I have not purchased the unit yet.
Maybe it was "operator error", maybe the mechanism needed lube or adjustment, or maybe it was fundamentally broken.
I think a copy of the operator's manual and/or shop manual would help me further evaluate the C99.
I think you have offered copies of these to others.
I am also in southern California (Tehachapi).
Regards -- James
conf
Gmorr, shoot me an email address via PM, that I can send attachments to. They are about 3 Mb each.
I think I got the others sent out.
To be fair: Ditch Witch tech support sent me the hardcopies for this long-discontinued trencher at no charge. They are a stand up outfit! Personally I prefer everything electronically so I woulda scanned 'em anyway.
/ Ditch Witch C99
I have sent out quite a few of them, and would be happy to share with you. You can PM me an email address that accepts attachments and I will get it right out to you.
Shifting is a pain but lube seems to help.
/ Ditch Witch C99 #35
Dear Daveshoot
I also just purchased C99 and I have been looking for both manuals. How much do you need for a copy of each. Thank you Jeff
/ Ditch Witch C99
Should be two emails in your Inbox!
/ Ditch Witch C99 #38
Hello, I have a c99 ditch witch trencher that I purchased a couple of months ago. I really need a copy of the manuals for it. If you could send me copies of the manuals you have I would really appreciate it. Thanks in advance for your time and help. David. ded77@bellsouth.net
/ Ditch Witch C99 #39
I just got hold of a c9 and have to do some work on it and haven't been able to find a manual showing the way it goes together. I would love a copy of the manual/parts if your willing to share. Bob@dadsmowerservice.com
I have found that 1) I can trench more with rentals than I can possibly install in one shot, and 2) trenches do not age well.
The upshot is re-digging all those trenches out by hand with a contractor's shovel, or cobbling up something that allows the CUT to help with the chore. Neither have turned out well for me. Rain also disperses or compacts your backfill.
So, I bought a trencher off of Craig's List. Been stalking them for some time, but the $$ or condition put me off. Until now....
This "antique" Ditch Witch C-99 is an awesome little digger. It was $950 and I will call that good. The rope start kicks it on first pull every time (so far). It was well cared for and home-serviced.
Shifting forward and reverse is a little tricky. I can share one painful way not to do it, but it works pretty well once you get the hang of it. I can run an easy 2' deep when and wherever I want, and it's at least a little more maneuverable in some of the tighter places.
You trench in the reverse creeper gear, and once it's all going you can sit down and watch. It will just pull a straight line unless you hit something you should have known was there. Or an undocumented rock.
If anyone else has one, I have scanned the owner's manual and have the parts book as well. It's been out of production since at least '99.
I have finally got my pipes from the well to the house (and under the driveway, courtesy of a rental UnderWonder) and am finally making some real progress.
BUSH HOG 4R48" ROLLING CULTIVATOR (A64278)
BUSH HOG 4R48"...
2013 CATERPILLAR 120M2 MOTOR GRADER (A63276)
2013 CATERPILLAR...
CASE INTERNATIONAL 5240 TRACTOR (A63291)
CASE INTERNATIONAL...
Woods 72" Brush Cutter (A64047)
Woods 72" Brush...
2017 FREIGHTLINER CASCADIA  125 6x4 T/A  SLEEPER TRUCK TRACTOR (A67147)
2017 FREIGHTLINER...
2017 CATERPILLAR 950GC WHEEL LOADER (A64279)
2017 CATERPILLAR...
