Distilling Lavender
/ Distilling Lavender #1
TWINKLE_TOES
My wife is a Lavender nut and has been after me to figure out how to distill Lavender./w3tcompact/icons/frown.gif I found a Lavender distiller on the web that costs as much as a good three point attachment but not much else. I'm not even sure of the basic principles of the distillation process other than I think the oil vaporizes a little before water and then is condensed. If anyone can help I would sure appreciate it. Thanks in advance.
AL
/ Distilling Lavender #2
Al
Been there, done that./w3tcompact/icons/crazy.gif I got my wife to settle for putting a little light oil in a jar packed with lavender and setting it in a non-South facing window. The oil will absorb some of the lavender smell, but won't be an "essential" oil. The price of essential oils is incredible. The wife buys "NOW" brand when she wants the real stuff. It's cheaper than most of the other brands.
I seem to recall something about steaming the essential oil from the lavender, but as I recall, it also required "pressing" at the same time. ie, a weight placed upon the lavender blossoms to help extract the oils. Comfrey is easier, just crush some leaves in a pan of oil or shortening and boil until everything turns green. Works great on burns and blisters. Don't believe the stuff about preventing bruises.
SHF
SHF,
Thanks, I'll try to convince her the oil absorption is the best thing since sliced bread, but I think she will see right through me. She grows a lot of Lavender and her sister lives in France and keeps sending her the good stuff. I think I am stuck with figuring out ($$) on how to get her set up to make the good stuff. /w3tcompact/icons/frown.gif
Al
/ Distilling Lavender #4
Al,
If my memory serves me correctly the best lavender EO is produced in a particular area of France. Some essential oils are picky about where they do best. Not to say that you cannot produce some good stuff here also. France is known for having a disproportionate (sp?) amount of specialists in EOs. Your wife's sister may be able to point you in the right direction better than any of us can.
DaveV
/ Distilling Lavender #5
Al
If by some chance you DO figure out a cheap, simple way to do it, be sure to pass the info on. That way I can stupefy and amaze the the woman in my life! /w3tcompact/icons/laugh.gif
SHF
DaveV
I think your memory serves you well. The general concensus from what I have read is "If it ain't from France, it ain't". As far as my wifes sister helping, she has done quite enough, she's the one that started this and she only deals in concepts (Al should be able to make something)
I'm sure if I keep after it the secrets of distillation will be mine.
Thanks for your thoughts.
Al
SHF,
I'm one up on you here, my wife is already stupified by my behavior. If I do get this figured out, I will pass it along.
At this point I am reduced to searching the archives of "Backwoods" magazine. (if you want to make lavender tea I can help with a receipe)/w3tcompact/icons/tongue.gif
Al
/ Distilling Lavender #8
Al,
Also check back issues of "Countryside and Small Stock Journal"
I know I've seen something about this before. Can't be too hard, people have been doing it for a long time.
SHF
/ Distilling Lavender #10
Al,
I think it also stupified my eyeballs. I had a chat with George Washington about this, and he told me he and his brothers don't want to go. /w3tcompact/icons/laugh.gif /w3tcompact/icons/laugh.gif
SHF
/ Distilling Lavender #11
If your wife will settle for Lavender perfume you (or your wife) can extract the Lavender fragrance in an alcohol solution. The process is known as enfleurage and is the classic technique for making perfume. It is a simple procedure and the equipment should be easy to jury-rig from your scrap box.
The essential oils are extracted into melted animal fat and then into an alcohol solution. The alcohol solution is separated from the animal fat by distillation.
Melted lard will absorb the oils from about 3 times its weight in flower petals.
You will need lard, un-denatured ethyl alcohol, and your source material. I know flower petals, Mint leaves, Bayberries, Cinnamon, Cedar and Juniper work well. I cannot see any reason Lavender would not work.
Melt the lard in a double boiler
Shred the Lavender (or whatever)
mix 1/3 of the lavender with melted lard let stand for about an hour in a warm place
Reheat and drain the lard
Mix the lard with the second third of the lavender and let sit for an hour
Mix the lard with the third third of the lavender and let sit for an hour
Reheat
Add 100 proof vodka (a source of un-denatured ethyl alcohol) and mix for 5 minutes
Place the lard-vodka mixture in a bottle with a single outlet, connect a simple condenser (a foot or two of metal tube coiled) and place the bottle in boiling water.
The alcohol with the fragrance will drip out the condenser.
For ¾ pound of flower petals use ¼ pond lard and 1 oz Vodka.
You will change the resulting perfume by changing the time extracting the fragrence from the Lavender into the lard and also the time extracting the fragrence from the lard into the alcohol.
The result is a strong perfume. To make Cologne dilute the perfume with alcohol as needed.
Edmund Scientific has a kit with the bottle and condenser.
http://www.edmundscientific.com/Products/DisplayProduct.cfm?productid=648
The kit price is less than any of my three point attachments but you might have everything you need in your junk box.
Ed
/ Distilling Lavender #12
A reminder from my old Organic Chemistry Lab days - ethanol is flammable! (They do mix it with gasoline). Ethanol vapors are also heavier than air, and as it evaporates the vapor will roll off the counter onto the floor, creeping some distance to reach an ignition source. If ignited, it will burn with a blue flame on the floor that is difficult to see until the yellow flames come from your pants and shoes. Had a couple wicked methanol fires in the lab next door! Catching your feet on fire may be preferable to worst case scenario - vapor reaches high enough concentration before ignition and explodes. (Gee Mr. Science, that was really neat, can you do it again?)
