Disc
looch
QC, Canada
CK2620 SE Cab
I really like the looks of <A target="_blank" HREF=http://www.landpride.com/lp/products/dh15_specs.html>this style</A> of disc, but I found the price to be a little prohibitive. To me, the frame does not look terribly difficult to construct. Does anyone know if you can by just the discs already ganged on a shaft?(I know you can buy them individually).
Paul, see if you can find a farm equipment salvage yard in your area. One walk around and you'll have all sort of ideas for new stuff. You could probably get disc gangs from a larger implement and cut them down to suit your needs. Prices are generally pretty reasonable on the used stuff /w3tcompact/icons/smile.gif
/ Disc #3
That style of disc is pretty common. I have one from the 60's built by fort... almost identical.... but a bit rustier...
Tractor supply sells an equivalent. There are two major types of gang/axle setups. one that uses sealed bearings, and another that uses a grooved cradle, with grease fittings.
All the parts can be bought sepperatly.. the square axle, side axle plates, discs, disc spacers, cradles for the 'bearing spacers.
Possible the hangers that hold the cradles may have to be fabricated... but it is just an L shaped bracket more or less.
Chris
213078 (A64276)
213078 (A64276)
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A62129)
2019 VOLVO A45G...
48x4 Mini Skid Trencher (A63689)
48x4 Mini Skid...
New/Unused Quick Attach Hydraulic Rock Hammer (A65583)
New/Unused Quick...
Ford Tractor (A62613)
1997 Capacity Spotter Truck (A62679)
1997 Capacity...
