Disappearing coolant
/ Disappearing coolant #1
arrow
Super Member
Wakefield, RI
Mahindra 3016
I am wondering if anyone's tractor does this same thing. Coolant level up to full in radiator and overflow bottle. I'll run tractor for an hour and anywhere from 1/4" to 1/2" coolant level diminishes. No matter how many times I'll fill it up, does the same thing. First suspected a bad radiator cap but this tested 0k, then a bad head gasket. No external leaks and no wetness on radiator rods and not the slightest, smallest drip on ground. Tested for CO in coolant - negative. No weeping at water pump. Tractor (JD 750) runs strong with no tell tale of head gasket leakage such as white smoke or grey residue on oil cap nor coolant detection in oil. (which CO test confirms) The coolant just seems to "evaporate" but the engine never gets hot and runs very cool.
I know JD has a "non evaporative" coolant and was wondering if this is the reason why as I have not used their coolant. I know a bit about car engines but not as much with small diesels so this is a bit of a mystery to me.
/ Disappearing coolant #2
You are losing only 1/4"-1/2"? Or losing that much each time you run?
I believe you are filling up just a little too much for what your system requires and it is spewing it overboard. Its very little, so it would go unnoticed. If it stays 1/2" low, just leave it. it will be your new normal..
That's the trouble Midnite: it won't seek a steady level. Yes, each time I run it this happens. I idled it for an hour yesterday at different rpm's with the hood off looking for any tell tale….nuthin. No spewing, seepage or anything. It'll empty an entire bottle over time if I let it go. Pressure test on radiator reveals no leakage. Thought it had to be a head gasket but all testing reveals nothing of the sort. One would think with a compression ratio between 20-22 to 1, a blown head gasket would be quite evident on a diesel.
/ Disappearing coolant #4
Ya, definitely sounds like a slow head gasket leak. At the moment though, and something to think about - I have a car that is losing coolant too. Mine I am sure is a small leak as I can get a faint whiff of hot coolant smell while idling, say at a drive-thru. I too cannot find any hint of just where it is leaking, but I know it is. Its just soo small a leak it turns to gas as soon as it escapes. They make a radiator dye that i am gonna try next. You put it in, drive a few times, then check with a black light..
UVIEW Radiator Coolant Dye 6 - 1Oz Bottles: Heating, Cooling, & Air Quality : Walmart.com
/ Disappearing coolant #5
It's sounds like you've covered most of the usual suspects already Arrow. I couldn't tell from your description if you've had the crankcase oil lab tested (UOA) - if not, I'd send off a sample for a lab test.
I don't know these new coolants as well as I'd like, but from your description it sounds like the volume you are losing should be visible in the oil if it is a head leak. But, given how little I know about these new coolant formulations, maybe not (?).
Strange one, pls keep us posted.
(P.S. - is "very cool" running typical for your model of JD ? If not, that may be another clue.)
Best luck, Rgds D.
/ Disappearing coolant #6
1/4" to 1/2" each run and does not stop.
that's not alotta water. surely not enough to see steam out the stack. it could very well be burning it at a microscopic level.
with that lil.. i bet if you pull an injector it might not even be celan.. though would not hurt to look.
That's another corundum for me. I wouldn't think a diesel would be capable of a "slow" head gasket leak considering the compression they run at. I'm wondering if a small crack in the head may be more the culprit but as I said, don't know about these little diesels. But in either case, I'm thinking the fluid in the test container would have turned green with even the slightest amount of CO in the radiator.
Dave, good points about the lab test. For the amount I'm losing, you would think 1. it would be visible. 2. the oil level would go up. I as well do not know the behavioral characteristics of the newer coolant formulations. The JD has always run cool.
SG, could you elaborate on this please? I'm thinking you may have meant the injector may not be "clean" but you are still losing me if that is indeed what you are saying.
Midnight, this could be a bad backing plate seal behind the water pump. This is especially so if your vehicle is a Chrysler product in the 318-360 range.
/ Disappearing coolant #10
Sounds to me like a cracked head or cylinder wall and its blowing it out the exhaust. We've had that happen in our big diesel trucks before. Good luck, hope you solve it.
/ Disappearing coolant #11
I would replace the radiator cap. You would think that the overflow bottle would catch anything it lets out but it's cheap and it's the one part of the system that you don't test when you do a pressure test.
/ Disappearing coolant #12
Old Datsun truck did the same thing. Head was warpped and it was using very small amounts of Prestone. Just disappeared out the muffler. Took it to a shop that made their living fixing this problem. Have you ever had to run it hot for any reason?
/ Disappearing coolant #13
It's likely being burnt in combustion and being vaporized as it goes through the exhaust. Small amounts might not show up as smoke.
/ Disappearing coolant #14
Pull the head. If the carbon build up in the cylinders is pretty well gone you know there is coolant getting in somewhere. Might have to take it to a shop for the tests to find the crack.:(
/ Disappearing coolant #15
So if you run for 2 hours, does it drop 3/4 to a full inch? Does it ever drop below the core?
Sent from my iPad using TractorByNet
/ Disappearing coolant #16
Check the exterior sides of the engine block carefully. Could be a hairline crack in the thinner parts of the casting where the coolant passages are located.
When I had the Hercules engine (4 cyl, gas, 27 hp) rebuilt for my 1951 Minneapolis Moline BF tractor, we found such a crack. The engine guy was able to braze it OK.
The block on my Farmall Super A has a similar crack that the previous owner repaired with epoxy.
Good luck.
Tested cap and is fine. Holds a steady 13lbs after 28 years. The longer I run it, the farther down the coolant goes so I'm guessing its a slightly cracked head at the exhaust. Here's a $700 bill for a new head I didn't want.
Yes. Always catch it in time before that happens.
/ Disappearing coolant #19
i type on a tablet.. so get plenty of misspellings.
word was clean.
normal on a good head gasket or other leak that is going into the combustion chamber.. you get steam cleaned parts.
plugs on gassers.. and possibly injectors and gp's on diesels.
at 1/4" loss.. it simply maynot be enough.
with no steam in the stack.. no external leaks.. and no oil in the water and water in the oil. it's either boiling off thru the cooling system.. or going out the tailpipe in non sufficient amounts to steam.
i'm not a mechanic.. but those have been my observations over the years...
/ Disappearing coolant #20
I would agree with the cracked head and its burning out the exhaust. You could purchase some fluorescent die and put it in the coolant, a black light inspection should then show where it is going.
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
2025 Kubota RTV520 4x4 Gas Utility Cart (A66734)
2025 Kubota RTV520...
2006 CHEVROLET EXPRESS 4X2 SERVICE BOX TRUCK (A69167)
2006 CHEVROLET...
CATERPILLAR C1.5 LITER (CONDITION UNKNOWN) (A68842)
CATERPILLAR C1.5...
60in. Loader Forks and Frame Attachment (A61572)
60in. Loader Forks...
2014 LEVIATHAN  T-BELT TRAILER (A67714)
2014 LEVIATHAN...
