Dig septic bed with front end loader
/ Dig septic bed with front end loader #63
I would dig ruts, put pipe down, cover it with gravel and run a pipe to closest ditch. Who’d ever know?
BE A MAN!
I guess that’s a solid idea if you want to your house condemned, utilities shut off and your house be unsellable until it’s brought up to code.
/ Dig septic bed with front end loader #64
Lots of low income people here just run the pipe to the creek. Mine is up to snuff, but I have seen many trailers with a 4 in pipe sloping to the woods.
/ Dig septic bed with front end loader #65
There's a small town SE of us that had an open ditch behind all of the houses. Their sewage just went straight into that. For decades. Then, as I recall, it overflowed into an AG drainage ditch and then into a river. I believe they had to start a sewer district and everyone had to hook up. The water table was too high and the lots too small for septic systems. Cost a lot of people a lot of money.
Well to answer my own question, it is not only possible.... I did it. Had the help of a New Holland FEL as well. Carefully researched my plans and went over them with the inspector with my county before I started.
/ Dig septic bed with front end loader #68
Many jurisdictions only count sidewall surface area to achieve the square footage for a system. So a trench that is narrow is the least expensive. I used to argue with them about counting the ends when I was designing them.
/ Dig septic bed with front end loader #69
CONGRATS!
Looks great.
Can you give us a rough estimate of the man hours it took?
Digging the hole took a full day with two tractors at time or 1 tractor and a man on the laser level. Day two was putting in the 6" of gravel and then laser leveling the pipe. Also on day two the pipe was covered with 2" of gravel with tractors riding on 2x12 lumber. Got it all the way to being ready for inspection on day two leaving just the header uncovered.
It took about another 6 hours with two tractors to carefully backfill using heaving 3/4 plywood with 2x12's on top of that to backfill. Had one tractor running on the lumber in the pit and another dumping dirt in from the side.
Not counted in all of this was the time to add a effluent filter at the tank outlet, fine grading with rakes, and dealing with buying all the pipe and doing engineering drawings of the layout.
/ Dig septic bed with front end loader #71
Heck, I could have done that in a couple of months :)
Looks like a job well done.
Thanks for the numbers.
By your description that might figure up to about 3 plus full days for 2 people and 2 tractors.
That's about right. Keep in mind that the digging here was easy. Almost 100% sand except for a tree stump that had to be removed.
2014 Honda Accord Coupe (A61574)
2014 Honda Accord...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
3PT BOG HARROW (A63291)
3PT BOG HARROW...
REDDICK OFFSET DITCHER (A63291)
REDDICK OFFSET...
