Different Trees - Different roots
/ Different Trees - Different roots #1
Tdog
Platinum Member
SE Louisiana
BX22
I've dug up a goodly number of trees since I've had my BX-22. I am surprised at the difference in root systems from tree - tree. My worst/hardest trees have been sweetgums. When the gum tree is small, it is easy prey. When they get a little size, I've found that they have a tap root that I just cannot get to with my hoe. Attached is a relatively small gum tree, maybe 10" at the base. I've severed all the roots I can get to, but you can see a tap root that looks like an extension of the trunk that extends straight down.
After fretting with this little tree for tooooo long, I finally reached for the Stihl & took it off well below ground level [2nd post].
What I'm saying is that I expected oaks to be the toughest customers, but have not found that necessarily to be so.
2nd picture
/ Different Trees - Different roots #3
Tdog,
</font><font color="blue" class="small">( My worst/hardest trees have been sweetgums. When the gum tree is small, it is easy prey. When they get a little size, I've found that they have a tap root that I just cannot get to with my hoe. )</font>
I don't think that I've ever taken out a gum, but black walnut trees have a similar tap root. I've got lots of them and although a top will occasionally snap off in high wind, I have yet to see one uprooted.
/ Different Trees - Different roots #4
In 1995 or 96 I went on state active duty with the National Guard after Hurricane Opal hit Alabama. I seen many large oak trees blown over in south Alabama. I was surprized to see that they just blew over and didn't break. The roots appear to have spread out from the tree just below ground level.
Then today I was pushing over some peach trees for my brother and noticed that they didn't have much of a root system at all.
/ Different Trees - Different roots #5
Keep an eye on it. Gums are notorious resprouters. Cut one down and 4 will sprout from stump if left unattended. Even stray roots will sprout far away from trunk of dug up tree. Gums have amazing propensity for self preservation.
You're right, MMM. I've noticed the same thing.
/ Different Trees - Different roots #7
Wait until you encounter a hickory. They didn't call Andrew Jackson "Old Hickory" for nothing. /forums/images/graemlins/grin.gif
TK
/ Different Trees - Different roots #8
</font><font color="blue" class="small">( Keep an eye on it. Gums are notorious resprouters. )</font>
Painting the cut end with a mixture of Roundup and kerosene helps a lot.
/ Different Trees - Different roots #9
Never recall having to deal with a gum tree but Elm trees have a very heavy root system as well. I've seen people dig for hours to get 1 stump out. (same driver, equipment and size stump could do cherry, maple or oak in 1/2 hour or less).
/ Different Trees - Different roots #10
Hello Tdog,
Isn't it amasing what the BX22 can accomplish? I've been removing trees on my property here on Long Island, for the last two weeks. Although, L.I. is all sand and easy digging, the root balls on some of the oak trees are quite large. Attached are a few pictures of a stump I've been working on for the last two days. I used a 3 ton rachetting chain fall and the BX 22 to remove this stump. We finally won the battle! It came out today.
gugy, I can see where that would definitely be a 2 day job - or more - with a BX-22. Looks like it was made nastier because of another tree adjacent to where you are working.
/ Different Trees - Different roots #16
Tdog & MMM.... Usually I spread table salt real thick on top of the cut after wetting the surface. That keeps the tree from resprouting and starts the decomposing cycle.
/ Different Trees - Different roots #17
Poncho, that's one I've got to try! I can get quite a few sacks of salt for the price of a quart of Roundup. Excellent idea!
/ Different Trees - Different roots #18
Around kansas, we have some stubborn trees with an interesting tap root. They are called Hedge, or Osage Orange. Ive been told that they are in the mulberry family of trees. Mulberry also has a long, long tap root. The Hedge trees arent too difficult to rip out, but I have a technique that works well.
First, I try and push the tree up off the ground about 3-4 feet with my kubota L3130. Then, once Ive loosened it by pushing on it, I hook up the chain and rip her out. Not many trees can stand that kind of extraction around here. Ive only pulled little trees this way, tho, I admit. Usually, Im limited to about a 3 to 4" diameter tree. The bigger ones, I havent figured out how to rip out....any ideas?
dwight
/ Different Trees - Different roots #19
I have to agree with TK....those hickory are really surprising. I've been doing some clearing of woods over the past yr with a small backhoe. After taking down some pretty large trees, the biggest surprise I got was from a 3 " hickory. I thought I would make quick work of it...but boy did it fool me. It was just all tap root that went to China I believe.
sassafraspete
/ Different Trees - Different roots #20
Take out feeders before pushing. I usually drop fel bucket abou 3 or 4' from tree and dig up feeder roots, dump dirt , raise bucket 5 or 6' and push tree over all in one stroke. Height I push on tree depends on size as smaller ones will break. Larger/stubborn trees take more feeder removal and pushing. Often the taproot breaks off below ground level. This works on a lot of trees up to 8-10", but gums are really limber and have the thick tap. Ive dug all around them as in above pic and tried to push them over, but they just bend over. Frustrating.
2004 Ford E-450 Jayco Escapade 28G Class C Motorhome (A61569)
2004 Ford E-450...
1994 John Deere 6300 (A60462)
1994 John Deere...
2007 International 7400 T/A Altec D4050A T 50ft Insulated Digger Derrick Truck (A60352)
2007 International...
GENERAC MAGNUM PORTABLE LIGHT TOWER (A59823)
GENERAC MAGNUM...
(INOP) 2019 FORD EXPLORER (A59823)
(INOP) 2019 FORD...
2025 Pabreak Hydraulic Excavator Arm with Tooth Bucket Skid Steer Attachment (A61567)
2025 Pabreak...
