Differences in Gear speeds
/ Differences in Gear speeds #1
farmertracie
Hello fellow farmers,
I have a new holland tc35 and trying to figure out the differences in speeds between each gear between low 1-4 to med 1-4. Does anyone know?
Also what are the best gears for pulling a plastic mulch layer, one subsoiler, 4' bed maker, 5' harrow, and 5' rototiller?
Thanks so much and have a wonderful holiday...
/ Differences in Gear speeds #2
Welcome to TBN. Good folk's, lot's of advice and the price is right! :D
Many owner's manual's will provide a speed range for each gear - if you don't have one - your local dealer or a search on the Internet should give you a few options.
The question regarding the "best" speed for using the various implements will depend greatly on a few variables... soil condition - dry or wet. Soil type - sandy, rocky, light clay, heavy clay. Current vegetation cover - tight sod, brush, small trees, tall; heavy grass, etc.
Your tractor has more than enough power to "run-away" with the size of implements you listed.
Always take your time and go slowly... You can stop quicker and you can avoid damaging the attachment or the tractor or a nearby fence, etc. Once you're comfortable running the implement and have determined that you're able to work the ground successfully in the manner that the particular implement is designed; you can always go faster.
Gear choice will depend upon those conditions I mentioned previously as well as the type of attachment. The rototiller will take more power to run and you'll have to go slower than; say, with the disc harrow. And, I'm guessing that the plastic mulch layer attachment won't take very much "uummphh" from your tractor to run at all.. But, to successfully use that attachment - I seriously doubt that you would want to run in the highest possible gear - although; I'll bet your tractor could do it!! :eek:
Best advice - just DO IT - cautiously: until you know how each of the attachments do the job they're supposed to do and you're comfortable working with them. As long as the tractor isn't bogging down and losing rpm's or racing at the top of the tachometer scale - you're probably in the right gear... :)
Best of luck.
AKfish
/ Differences in Gear speeds #3
ak, i couldn't have said it better myself:D very good explanation. every new tractor owner should read that.
/ Differences in Gear speeds #4
Appreciate that - thanks.
AKfish
Thanks AK, really appreciate the thorough response. I've owned the tractor for almost 10 years now, but don't actually know what speed I'm going, was trying to estimate hours so I don't overschedule tractor hours this spring. The mulch layer does go fast usually do in med 2nd-3rd, and low 1 when I'm rototilling. I guess I'll just have to time myself better this spring...
And I'll check my manual, why didn't I think of that!!! I like your quote, so true, though wouldn't mind the view out my window. Too bad there isn't good soil on mountains!
/ Differences in Gear speeds #6
Most tractors have a speed chart plate on the tractor as well. My older NH compact has it on a fender, some have it on the dash, or below the dash? Would think you'd notice than in 10 years time tho, so maybe the new compacts no longer have it.
--->Paul
2019 John Deere 460E 46 Ton Articulated Dump Truck (A64194)
2019 John Deere...
Polaris Ranger 1000 (A64127)
Polaris Ranger...
2007 Peterbilt 378 (A62679)
2007 Peterbilt 378...
New/Unused AGT 3000PSI Hot Water Pressure Washer (A65583)
New/Unused AGT...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
Ellis Band Metal Saw (A62679)
Ellis Band Metal...
