did you know
/ did you know #1
bigbull338
Elite Member
texas
7040 HDC 1153 fel
that the 7040 motor is in the 8540 9540 an 105 kubotas.the only differance is the motor is turned up an a bigger turbo is put on.i found that out talking to a buddy about turning my 7040 up.an he told me this info.
/ did you know #2
Sorry but your buddy is incorrect as M7040(203 cid) has a smaller engine than a M8540/M9540(230 cid)
/ did you know #3
You are correct, there are different engines between the 7040 and the 85/9540. If you look at the specs, the HP difference between the 8540 and the 9540 is pretty small. Its the same base engine in those two models with external variations.
/ did you know #4
The Question should be can you put the TURBO off of an 8540 on a 7040 as a direct bolt on or do do you have to modify it to fit if so what do you have to do to make it work?
/ did you know #5
Buy the bigger tractor. There will mods all through the drive line for the higher hp.
/ did you know #6
Why would you want to put the turbo on a 7040? I'm assuming the 7040 is a non-turbo? The turbo only adds 1 or 2 hp vs the non-turbo model (9540 vs 9540DT). The turbo is for pollution control, not horsepower. Personally, I'd prefer the non-turbo engine, you don't have to sit there and let it idle before shutting off to cool down the turbine bearings. YMMV.
/ did you know #7
Turbo is for power, way more than 1 or 2 and is not for pollution control
/ did you know
the 7040 has a turbo on it.but turning the motor up an changing the turbo would be cheaper than buying a new tractor unless you wanted a new tractor.the only reason i mentioned it is because it would be fun todo if you had the money an some1 you trusted todo it.
/ did you know #9
The newer 7040 may have a turbo to meet emmsions but the older ones do not
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2010 KEYSTONE LAREDO (A65643)
2010 KEYSTONE...
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
New/Unused Landhonor Mini Skidsteer (A65583)
New/Unused...
UNUSED WOLVERINE TDB-11-66W 66" BUCKET (A64281)
UNUSED WOLVERINE...
