Deutz Tractors?
/ Deutz Tractors? #121
Why would it be harder to start in winter than a liquid cooled engine?
I assume he said that because there's no water in it to preheat the engine.
IF his Deutz had good compression, a good batt./starter and cables, AND had a good working glow plug, it would start easy in cold weather, no matter how cold it got.
All of mine have...
SR...
/ Deutz Tractors? #122
That was my point, I could not see why an air cooled engine would be harder to start. Of course you're right no rad or block heaters on those.:)
/ Deutz Tractors? #123
Many years ago when I worked in the mining industry up north big deutz diesels were used in underground mining machines . When the machines where above ground and needed to be started in the cold weather -45 we had a salamander heater mounted on a cart that would line up with that air intake for the fan and we would let that heater blow hot air until the heat gauge started to show temperature rising! These big diesels had air motor starters so you made sure that you had a source of clean dry compressed air because if you had wet air going in the starter motor froze solid.
Hyster H155 XL Forklift (A59213)
Hyster H155 XL...
1999 Sterling L9513 Tri-Axle Roll Off Truck (A61568)
1999 Sterling...
2012 GROVE TMS900E TRUCK CRANE (A58214)
2012 GROVE TMS900E...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
2022 Brush Wolf 4800X Severe - Duty Excavator / Backhoe Brush Cutter (A57024)
2022 Brush Wolf...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
