Desperately need to fix driveway
   / Desperately need to fix driveway #41
The problem with the box scraper is that the height has to be adjusted above grade with the hitch control or it wants to move massive amounts of gravel (as is its purpose), and once adjusted it will only make the washboard worse as the tractor rear end rocks up and down on the existing hills and dales. It really needs to float on the surface.
Comments?
Try lengthening the top link all the way so the box blade rides on the rear blade only.
Bruce
   / Desperately need to fix driveway #42
THIS COULD GO ON FOREVER and now for my
drive way its only approx 500 ft and when it rains on it I get pot holes and its caliche have water run off from
the neighbor so think will put a cattle guard in there
so water will run under it because a pipe will fill up
with dirt etc.
WILLY
   / Desperately need to fix driveway #43
A Cat grader at work. The rear blade With gauge wheels tries to emulate this action.
A rear blade is the proper tool for the OP problem.
There is a learning curve for it's use however.
Think EA Deluxe Scrape blade, particularly if it can be adapted with gauge wheels.
Egon has exactly the correct suggestion.
   / Desperately need to fix driveway #44
My suggestions are simply age old road building techniques which have stood the test of time. They were used well before my time!
There are innumerable articles on aggregate sizing and compaction.
As to equipment look at You Tube. Lots & lots of information on all the latest and best tractor pulled implements and their really ā€œgood looking productā€œ that would never meet proper inspection methods. Then look at construction roadwork equipment and methods that have to meet tested conditions. ( A lifetime ago I was on site for many a day of grade construction. ā€œ) (equipment of the time will date me; D9H, Cat 631, cat 641, Cat #16, first ones, cat 14, cat 12, vibratory packers drum & sheep’s foot, 988. I did not operate.)
In Europe there are quite a few tractor based road renovation implements. Some will be very effective But probably very costly.
   / Desperately need to fix driveway #45
As to equipment look at You Tube. Lots & lots of information on all the latest and best tractor pulled implements and their really ā€œgood looking productā€œ that would never meet proper inspection methods. Then look at construction roadwork equipment and methods that have to meet tested conditions. ( I have been on site for many a day of grade construction. ā€œ
Re roadwork construction: Think they will ever finish NS 103?
Little bits over time = forever!
   / Desperately need to fix driveway #46
The main road does not need to be higher than the surrounding terrain...As long as the flow line of the ditches is below the driving surface and they are wide and deep enough to carry the capacity of runoff...
I initially took issue with this statement. Then upon further reading, I understand what the commenter is saying.
However when folks say the road must he higher than the ground around it —it must be!
A road with a ditch beside it that has a lip where the toad is lower then the lip going into the ditch (look at photo with trees on right side—left side of photo can not shed water) will not shed water. If there is a slope running the length of that road, it will erode the drive. If it is flat, it will effect the base of the road from standing water seeping in soil.
Water shedding/drainage is also the priority for the driveway.
The coverings largely depends upon your location and soil types—there is no 1 solution.
Point in case what works in clay soils will not work in sandy soils.
   / Desperately need to fix driveway #47
I just when back and looked at OP’s 1st post. Particularly at type photos posted.
Some specific comments related to the photos
1) forget trying to crown your complete driveway!
Folks before you go wild!!!! go look at the 2 photos!!! She has spots shown that are mild banked curves, water will always drain to the low side. If you have a stretch of flat area, crowning would be good in those areas.
2) you need ditches! With the trees close to your drive that can be seen, you may not be able to cut ditches with your tractor. Some trees will have to go, while others are going to have roots where you need the ditch to be. Personally, if I were doing it, this is a job for a medium sized mini excavator. Once a ditch is established, by picking the ground conditions it can be maintained and shaped with your tractor and an offset rear blade.
It is difficult to tell based upon the limited view of the photos, but full length ditches may not be what best meets your needs. ā€˜Short’ (relative term) ditches on the bottom on the curve slope dumping into a natural low spot, built retaining pond, natural creek or other water control feature may better serve your needs.
3) with those ā€˜banked’ curves, you will have gravel movement. In my opinion it will be pushed to the high side by vehicles traveling too fast. As well as water flow and gravity will roll gravel down hill. You can reduce some of both effects with some fines in the gravel. You do not ever want to have ā€˜creek’ gravel on those areas. In my area, creek gravel is often solid my land owners that have creeks on their property. It is typically very smooth and will roll/slide always.
   / Desperately need to fix driveway #48
Shot, shot...
Chaser
LoL...Exactly what is it you don't understand ??...an open storm water sewer is not so different than a contained system (pipes/catch basins etc...)...it all about gravity and flow line elevations...
If a road bed is significantly higher than the surrounding terrain...if the road, lane etc is crowned there is no need for ditches...
...try cutting a road through the mountains and making the road higher than the mountain...LoL...!
So in other words, the road needs to the high point in the equation. Ditches always have a fall line down hill, but laterally, they still need to be lower than the road surface to drain water with the crown as the force of gravity.
   / Desperately need to fix driveway #49
Seeing as my travelling is limited off peak traffic hours suit me fine. Chances are it will get finished just as more upgrades are required.
   / Desperately need to fix driveway #50
"Crusher run" (usually defined as 3/4" minus) packs tightly together and is what works best.
"Creek gravel" is small rounded stones, and will not stay in place!
   / Desperately need to fix driveway #51
Buy a 4x4 , problem solved.
   / Desperately need to fix driveway #52
   / Desperately need to fix driveway #53
Shot, shot...
Chaser
LoL...So what exactly does stating the obvious have to do with anything?...LoL
You misunderstood what I posted....you should have just read it very slowly until you understood...!
The point was that several replies indicated that the road bed needed to be built up higher than the surrounding grades...I merely pointed out that you don't need to raise the road just lower the ditches...get it now ?
BTW...this is all basic stuff for those of us that went through 'route location and design' courses on the way to civil engineering degrees...!
   / Desperately need to fix driveway #55
I actually still do remember those basic premises from my CE highway design courses of 60 years ago.
   / Desperately need to fix driveway #56
Ditches need to go down hill...but the road needs to drain latterly to get into the ditch. Which means the road needs to be higher than any ditch.
Now your a civil engineer too. I thought you were a world renown AI guy. You're an expert in everything I see...
   / Desperately need to fix driveway #57
LoL...ditches are not the surrounding terrain...duh...! like I said if the road was higher there would be no need for ditches (in many cases)...
You build the road then cut the ditches...you don't dig the ditches and then build the road up higher...LoL...!
I spent 40+ years as a GC...educational background was a plus but never certed as a CE...late in life I went back and studied computer science (UNIX system admin)....what I've learned about AI has mostly been from reading and listening to lectures
   / Desperately need to fix driveway #58
Well we could argue with each other until this thread is 10+ pages long, but Graziaka (OP) is awol, so....
I'll just say here, for the record, that I am personally the single most knowledgeable gravel driveway expert on this entire forum. :p
But I like my ditches to be about 2 to 3 feet higher than the road bed. Takes a lot of experience to get them shaped up for inverted water drainage.
   / Desperately need to fix driveway #59
I must have missed that lecture in my long ago CE class days!😬
   / Desperately need to fix driveway #60
This style of of grader or drag has proven itself many times over.
A simpler version can be pulled with chains attached from the 2 front corners.
The angled blades slice bumps and move the material laterally so as to fill in dips.
Blade lengths are adjusted so that material from the front blade is caught by the next one with the rear blade acting like a finish blade.
We maintained a much travelled 4 mile country for many years using an old Jeep as our tow vehicle.
Since we'd often snag our drag on rocks and feared pulling the Jeep bumper off we looped the chains thru a 12 inch trailer tires and they acted as efficient shock absorbers.
3 or 4 inch channel or angle is all U need (and a good welder).
2019 CATERPILLAR 972M WHEEL LOADER (A60429)
2019 CATERPILLAR...
2014 Ford Edge SUV (A56859)
2014 Ford Edge SUV...
2025 HT360W Mini Stand-On Track Loader Skid Steer (A59228)
2025 HT360W Mini...
KUBOTA M8540D TRACTOR (A60430)
KUBOTA M8540D...
CATERPILLAR 255 SKID STEER (A52709)
CATERPILLAR 255...
2015 Kubota RTV-X900 4x4 Diesel Utility Cart (A59228)
2015 Kubota...
