Decompression control
/ Decompression control #11
"It is full on or full off."
I'm not sure I understand that. I haven't actually looked at the mechanism, but doesn't the mechanical connection dictate that it has to open and close the valves according to how far you pull the lever to open or push it to close?
/ Decompression control #12
/ Decompression control #13
Yes, u right but it is not to be used that way. Should be either full open or full closed.
/ Decompression control #14
/ Decompression control #15
Yes, it should be USED full on or off, however your response is misleading him. This lever doesn't have a A or B position. It can be held, quite easily, at any position in between full open or full closed. If the lever isn't returning to the fully closed position, then he needs to address the problem.
/ Decompression control #16
/ Decompression control #19
My response wasn't specifically directed to you, just to the concept that the lever worked on a all or none principle.
/ Decompression control #20
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
2014 Parker Trailer Sales Trailer (A60352)
2014 Parker...
CASE SV280 SKID STEER (A62129)
CASE SV280 SKID...
2015 ISUZU NQR 4X2 DEBRIS TRUCK (A59908)
2015 ISUZU NQR 4X2...
2020 LCMG AS1932E ELECTRIC SCISSOR LIFT (A59823)
2020 LCMG AS1932E...
2012 MACK CHU (PINNACLE) (A60736)
2012 MACK CHU...
