Decompression control
/ Decompression control #11
"It is full on or full off."
I'm not sure I understand that. I haven't actually looked at the mechanism, but doesn't the mechanical connection dictate that it has to open and close the valves according to how far you pull the lever to open or push it to close?
/ Decompression control #12
/ Decompression control #13
Yes, u right but it is not to be used that way. Should be either full open or full closed.
/ Decompression control #14
/ Decompression control #15
Yes, it should be USED full on or off, however your response is misleading him. This lever doesn't have a A or B position. It can be held, quite easily, at any position in between full open or full closed. If the lever isn't returning to the fully closed position, then he needs to address the problem.
/ Decompression control #16
/ Decompression control #19
My response wasn't specifically directed to you, just to the concept that the lever worked on a all or none principle.
/ Decompression control #20
Snap-On Gold Medal Tribute to Excellence Limited Edition 3-Bay Tool Box (A61307)
Snap-On Gold Medal...
2007 JLG 600S Manlift (A61166)
2007 JLG 600S...
(INOP) 1991 GMC DUMP TRUCK (A59823)
(INOP) 1991 GMC...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A61307)
2020 Takeuchi...
HYSTER 50 FORTIS STRAIGHT MAST FORKLIFT (A59823)
HYSTER 50 FORTIS...
HYDRAULIC TANK WITH COOLING SYSTEM (A60736)
HYDRAULIC TANK...
