Deck leveling for 62" mower
/ Deck leveling for 62" mower #1
bones72
Jd2210
An any member offer hints on leveling mower front to back
/ Deck leveling for 62" mower #2
search for 62c or 62d and you should get some hits, it has been discussed before..
All i can say is:
#1 - make sure your tires are at the air pressure you want and they are consistant from side to side..
#2 - find a level area otherwise you will just frustrate yourself..
Otherwise read the manual a couple times to fully understand how to do it..
Good luck
Brian
/ Deck leveling for 62" mower #3
Stop in at your local John Deere dealer and purchase one of the plastic deck leveling tools. Only cost 8-10 dollars and will be the best money ever spent on tools. You will be able to accurately adjust the front to rear and side to side measurements. Most people run the deck rake 1/8 to 1/4 inch higher in the back than the front. For mulching it is recommended a 0 inches difference.
Thanks for info. Have a gauge on the way. Closest dealer is225 miles west
Bones 72
/ Deck leveling for 62" mower #5
Setting the deck a little higher at the rear is key. Helps prevent blades from trying to double cut grass blades, causing grass blade tips to be shredded verses clean cut. Really important with taller fescues!
/ Deck leveling for 62" mower #6
Where did you get you gauge from?
Winnipeg Manitoba,canada
Thanks for info on gauge. Took very little time to adjust and cuts like a dream. Closest dealer is 225 miles
Bones72
/ Deck leveling for 62" mower #10
Ill order one today.
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59905)
1999 TRANSCRAFT...
2025 48in. Farm Jack (A61567)
2025 48in. Farm...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
New/Unused Landhonor Toolbox with 24 Ratchet Straps (A65583)
New/Unused...
NEW 2025 Mini Skid Steer Stand On Loader (A62679)
NEW 2025 Mini Skid...
Bear Statue (A64127)
