Deciding between L series & MX
/ Deciding between L series & MX
Thanks everyone!!!
Though now am having to contemplate an mx5800!
I do think I like the idea of a non turbo but I will have dealer price out the 5800 and see what it looks like.
Still think the hst is probably the way to go no matter the size.
My 7ft mower is a bit beat up perhaps will consider a new 6ft hd mower.
/ Deciding between L series & MX #22
I had a L3200 before upgrading to a L4060 for the cab. The new L4060 will do over an acre an hour mowing, the L3200 less. The L4060 is not enough machine to move 80 acres. The higher HP grands might be enough, but a MX will fit 80 acres a lot better unless you want to be mowing full time.
/ Deciding between L series & MX #23
go w/the mx 5800 & hd 6' mower you won't look back. been there before.
& get rid of present tractor to help w/upgrade been there too.... best regards
/ Deciding between L series & MX #24
John Deere 4020
1963 - 1972 New Generation Series
Row-Crop tractor
Previous model: John Deere 4010
Next model: John Deere 4230
Series next: John Deere 4320
Series back: John Deere 4000
Manufacturer: John Deere
Factory: Waterloo, Iowa, USA
Total built: 184,879 (total)
8,123 (gas)
8,445 (LP)
168,311 (diesel)
17,732 (standard)
Original price (USD)
$10,345 (1972 )
Variants:
4020: row-crop
4020S: standard
4020HC: high-crop
600: industrial
John Deere 4020 Engines:
John Deere 6.6L 6-cyl diesel
John Deere 5.6L 6-cyl gasoline
John Deere 5.9L 6-cyl gasoline
John Deere 5.9L 6-cyl LP gas
3-Point Hitch:
Rear Type: II
Rear lift: 3790 lbs [1719 kg]
Power Take-off (PTO):
Rear PTO: independent
Rear RPM: 540/1000
1000
Engine RPM: 540@1900
1000@1900
Front PTO: independent
Front RPM: 1000
Engine RPM: 1000@1900
Dimensions:
Weight (operating): 8,645 lbs [3921 kg] (gas syncro)
8,945 lbs [4057 kg] (diesel syncro)
9,240 lbs [4191 kg] (gas powershift)
9,560 lbs [4336 kg] (diesel powershift)
Weight (ballasted): 13,980 lbs [6341 kg] *
Row crop Wheelbase: 97.5 inches [247 cm]
Standard Wheelbase: 100.25 inches [254 cm]
Length: 151 inches [383 cm]
Width: 89.6 inches [227 cm]
Row-crop Height (steering wheel): 77.9 inches [197 cm]
Standard Height (steering wheel): 78.25 inches [198 cm]
Standard Height (exhaust): 88.25 inches [224 cm]
Row crop Height (exhaust): 88.75 inches [225 cm]
Row-crop 2WD turn radius: 9.9 feet [3.0 m]
Standard 2WD turn radius: 10.9 feet [3.3 m]~~~~~~~~~~~~~~~~~~~OP HAS WIDE FRONT MODEL.
4020 Serial Numbers:
Location: Serial number plate on the rear of the 4020 transmission case.
photo of 4020 serial number
1964: 65000
1965: 91000
1966: 119000
1967: 145660
1968: 173982
1969: 201000
1970: 222160
1971: 250000
1972: 260791
Final: 270288
Links:
Forty-twenty.com: Site dedicated to the John Deere 4020
John Deere 4020 Power:
Drawbar (tested): 83.79 hp [62.5 kW]
PTO (tested): 95.83 hp [71.5 kW]
Mechanical:
Chassis: 4x2 2WD
4x4 HFWD 4WD*
Differential lock: mechanical rear*
Steering: power
Brakes: hydraulic wet disc
Cab: Open operator station. Cab optional.
Page information:
Last update: August 30, 2017
Copyright: Copyright 2017 TractorData LLC
Contact: Peter@TractorData.com
/ Deciding between L series & MX #25
I maintain 80 acres with 50 in CRP, 10 or so cash rented row crop and balance 20 acres woods.
My main job is mowing fire borders, between trees, etc, but am needing to clear some blow down in the woods, get some rip rap along creek banks, maintain gravel drives better, etc. On occassion I need to pull a 10' glencoe cultivator and maybe a disc. my mower is 7ft
Right now, i use a gas 1966 John Deere 4020, wide front, NO loader. Its not all adequate...too tall for mowing under trees, huge turning radius.
The Deere 4020 is twice the bare tractor weight of the Kubota MX series. Tractor weight, not horsepower, provides most tractor 'grunt' in ground contact work. If the Deere has struggled with any of your current ground contact implements, a Kubota MX will stall out with same implements for sure. You may need lighter ground contact implements for the new tractor.
The Kubota MX series has larger tires than the Grand L series, based on the same frame, possibly with the same engine block. Larger MX tires (over Grand L tires) will provide more float over soft ground. Opting for bulbous, low pressure, radial tractor tires will increase float another increment, possibly crucial float along creek banks. Radial tires will lower tractor height 2" to 3".
Even with the ROPS folded the MX series will be as tall as the Deere 4020 exhaust at around 90"
(ROPS are tall to allow clearance for optional Backhoes. ROPS have to fold approximately in center not to interfere with rear Three Point Hitch.)
Judging by your property description an HST transmission will make operating simpler and somewhat safer.
Kubota 'Grand L' tractors have Kubota's wonderful HST/PLUS transmission.
Kubota MX series have standard Kubota HST transmission, no slouch itself.
VIDEOS (2): Kubota HST Plus Transmission Features - YouTube
Kubota Grand L Series VS. Kubota MX Series - YouTube
Minimum width on MX series is 70 inches. Wheels can be set wider.
Assuming you will order a FEL and R4/industrial tires, minimum width will be ~~ 76".
Cut a 10' stick of 1-1/4" PVC pipe to 84", mark at 76", then walk around your woods to see if an MX will pass where you want it to pass. 84" will allow for possible radial tires and indicate approximate Disc Harrow width.
An MX with 4-WD will pull a Disc Harrow with 22" diameter pans, a tad wider than the tractor tires. A Disc with 22" diameter pans will weigh around 1,100 pounds and will cut fire breaks nicely, probably two passes to establish, then one pass thrice yearly for maintenance.
Most cultivators only penetrate 3" to 4" deep. An MX with 4-WD will pull a 10' wide cultivator easily.
Turning radius for MX series with 4-WD is 8.9 feet. With implement raised, if you lock one brake you can revolve tractor in less space.
MX5200 and MX5800 will operate a medium duty twin spindle 8' Rotary Cutter/Bush Hog in grass to 40".
/ Deciding between L series & MX #26
Be very careful what you finally decide on. None of the new tractors mentioned will ever replace the bull work that your 4020 can do handily. I have had a Kubota L4200 for many years, soon to be replaced with a new L5060, but still occasionally call upon my neighbors JD4020.
I know you don't want two tractors, but I would not trade the 4020 in on a new tractor. Keep it for a while until you personally test the capabilities of the new, smaller tractor that you decide on. If you find it meets ALL your needs, then sell the 4020 outright.
/ Deciding between L series & MX #27
If going with Kubota, consider the MX5200 over the MX4800. MX5200 has that extra oomph to handle whatever I throw at it. I strongly recommend loading the rears or adding wheel weights.
I concur.
/ Deciding between L series & MX #28
Well, I have both, and these are two very different tractors. The MX is a great tractor, lot's of hp and much heavier - bigger. I bought the L3301 for the lighter chores, and it's great for that. If you want something in between, think about the 3901. I could probably do everything I want with my 3301, but it would be pushing it. Consider a gear drive, I love mine.
/ Deciding between L series & MX #29
I was going to get the MX4800
I decided on the MX5800 for the extra PTO HP
I was moving rocks and boulders yesterday the Hydraulic thumb is a must for plucking big rocks out of the ground.
I had one that would not fit in the front bucket and the 2' backhoe bucket and thumb could not grasp it so I had to push then drag and the push it again to move it.
I was very very happy that I bought the MX over the lighter L
I worked the MX5800 pretty hard moving that Boulder., The MX4800 may have moved it as well but having the extra 10HP may have helped some.
Nothing like feeling your whole tractor rise as a big big rock gets stuck while dragging it and the tractor keeps a moovin
Thanks oldoak & jeff!
Yes, the 4020 is beast...I've yet to bog that thing down and usually never even run in the pto range. It's drawback is it's size, huge turning radius and being gas, it does burn a fair bit of fuel. I have a 60x40 machine shed that is getting filled up, so was thinking the extra room would be nice and it doesn't have a loader and have some ditch banks that fell dicey when mowing.
The other pia item of the 4020 is the exhaust usually blows right back in your face....and when doing work with a lot of up & down its not too convenient
I'd only sell if I get what I paid (or more) years ago (7200)...so def wouldn't trade. I was thinking tho if I planned to keep the 4020 Id get a small l2501 or l3301
I do hate regretting selling things...but if I get a decent price, It does give me the reason to shop around for another nicer one, if I do have regrets or a nicely restore IH 686. But again maintaining one tractor sounds kinda nice too.
The info on the height here is surprising...I will need to go measure my 4020...The hood is right at 6ft and my exhaust sure seems a lot higher than the rops on the kubota...better measure tho!
One other task for this tractor is to maintain food plots. I'd like to get a rototiler and have a 1 acre food plot in a field and want to build smaller ones in the woods.
Has anyone had issues with the mx size tractor making good use of a roto tiller?
thanks again!
/ Deciding between L series & MX #31
Agree that the JD 4020 is a workhorse and there is no way that I would give one up. You would have to pry my cold dead fingers off of the steering wheel if I had one.
I would get a 3 sided RV carport and keep her.
Thanks!...Im sorry hydraulic thumb? Also you have the backhoe on your 5800?
/ Deciding between L series & MX #33
PTO powered Roto-tillers and Disc Harrows are both soil mixing implements. You need one or the other, both are needless duplication.
I slightly favor the Disc Harrow because it is faster maintaining fire breaks and does not require attaching Roto-tiller PTO shaft to tractor, always a struggle. Disc Harrows are among the easiest implements to attach to a tractor. However, Disc Harrow + tractor combinations are l-o-n-g. Roto-tillers are compact.
Forward rotating Roto-tillers require very little power. An MX can handle any reasonable width Roto-tiller.
I recommend a Cultipacker to firm seed into soil.
Also,
Can anyone tell me what Im missing on the comparison of the 4800 to 5800?
61.4 versus 49.3 hp? all other specs look the same. They appear to have same engine block, but the 12 extra hp appear to be coming from the turbo and the Te4-MX3 addtion on the engine. I assume the the TE4-MX3 is just bigger badder turbo than on the 5200.
hydraulic specs and everything else look to all be the same.
heck even displacement on l4700 vs mx4800 is the same. I see tho that l470 is called tier 4 and mx 4800 is call tier 4 final. Does that mean the mx4800 and above will require DEF but the L4701 would not?
/ Deciding between L series & MX #35
All of the specs are the same for the Front bucket and Backhoe between the MX4800 , MX5200 and the MX5800 the difference is the HP at the PTO
The MX5200 and 5800 are turbo'd
if you get the upgraded front bucket LA1065 and the BH92 Backhoe on the L4701 they all lift the same but the L4701 Hydro Pump 7.8 GPM is slower that the MX's 9.5 GPM
/ Deciding between L series & MX #36
The MX4800 has Three Point Hitch turnbuckle Lower Link stabilizers and fixed length Lower Links.
MX5200 and MX 5800 have Three Point Hitch telescoping, pin adjustable Lower Link stabilizers and extendable Lower Links, as do all the Kubota Grand Ls. I have never read a TBN post reporting damaged factory telescoping, pin adjustable Lower Link stabilizers or extendable Lower Links.
These refinements make connecting Three Point Hitch implements much easier.
As extendable Lower Links retract after implement attachment, this attachment method does not increase tractor/implement length. Aftermarket Quick Hitches increase tractor/implement length 4" (+/-) which often requires longer PTO shafts or adding PTO shaft extensions. I occasionally read TBN reports of broken aftermarket Quick Hitches, including broken Land Pride Quick Hitches.
No DEF.
I speculate cooling capacity increases with turbo addition.
MX5200 and MX 5800 have Three Point Hitch telescoping, pin adjustable Lower Link stabilizers and (I believe) extendable Lower Links, as do all the Kubota Grand Ls.
No DEF.
thanks!
Would the extras on the 3pt hitch on the 5800 give any benefit if i were to be getting a quick hitch 3pt attachment anyway?
The major advantage I can see of the 4800 over the l470 is the category 2 hitch and the extra weight.
Where does teh extra 500lbs come from? Are the axles heavier? the engine looks to be the same an assume the hst is the same as well.
/ Deciding between L series & MX #38
I looked at both of them and the MX axles are a lot larger that the L4701
the Cat 1/2 3 point hitch is much heavier on the MX's
as for the Thumb
it is a extra it is mounted just over the backhoe bucket I got the Hydro version instead of the pinned one
The hydro version is activated with a right foot peddle that keeps your hands on the levers for the backhoe.
Pretty neat design it works great
/ Deciding between L series & MX #39
thanks!
Watch the second video in Post #25.
Re: L4701 vx. MX4800
Originally Posted by bdhsfz6 3/06/2018
I own both a L6060 and MX5800. The most obvious differences are the larger front tires, more robust front axle assembly and transmission case on the MX.
No argument from me.
The larger front tires, more robust front axle assembly and transmission case on the MX are sub-assemblies which mount to the frame/chassis, or whatever it is best termed.
Sheet metal dimensions of the Grand Ls and MXs are easily researched and close. Sheet metal dimensions vary a bit, with the MX sheet metal more bulbous, so the sheet metal properly fits around larger front tires, more robust front axle assembly, transmission case and larger Three Point Hitch on the MXs. I maintain my speculation L4060/4760/5060/5460/6060 and MX4800/5200/5800 are assembled on a single frame/chassis.
I also maintain my speculation these eight models share a single engine block. Not total engine, just a common block.
Tractor models are produced in low volume. Manufacturers constantly seek to maximize common components for scale in purchasing and assembly line production.
LINK TO FULL THREAD: http://www.tractorbynet.com/forums/kubota-owning-operating/392204-l4701-vx-mx4800.html
These components form an extremely robust Quick Hitch or Semi-Quick Hitch.
The operating station on the MX and Grand Ls are more spacious and have a nearly flat floor. If you are 5'-11" or taller, the MX and Grand Ls will be more comfortable than L4701.
/ Deciding between L series & MX #40
Have an MX, very versitle. I believe mx 5200 is small price increase from 4800. Extendable lower links are nice feature. The rear remotes are very expensive. Negotiated one w/ purchase, should have bought two. Priced recently from dealer, it is sold through whole goods not parts. $550. For the kit, self install. Buy the telescoping stabilizers if not standard, they are a parts item, expensive. Better off negotiating these items over the entire purchase deal. If winters are a concern, there is a very nice all glass cab available for 4701 or mx, aftermarket, a down the road upgrade if desired. More advise, get the rear worklight. It is not LED as folks will suggest, but has integral switch, saves monkeying w/ lites on new tractor. Can add lightbar and stuff as time progresses. Here is the point, what is dealer incentive to sell you reasonable add ons, AFTER they have sold you the tractor. Get what you want in the package, be prepared to walk away and THINK about the,$$
Edit: my mx floor is NOT completely flat, there is a small center hump but not excessive. Not sure about 4701
floor? Stock suspension seat on mx is crap. Bought inexpensive replacement spring/hyd shock seat from tractor supply w/ manual lumbar adjustment and higher back. Big improvement. Seat height increased as well, better visibility.
