DAVID BROWN power steerin needed
/ DAVID BROWN power steerin needed #1
PILOON
Super Star Member
North of Mtl,Que,Can (Ste Adele)
MT180D
I have a buddy that owns a 1971 David Brown mod 880.
The power steering cylinder incorporates a built in valve assy that is un repairable.
If anybody can source a PS unit, I'd be appreciative.
/ DAVID BROWN power steerin needed #2
Check with your Case ag dealer. Case bought out David Brown in the early '70's so they should be able to get parts for an 880. We had a '76 990 Case/David Brown. I got all my parts from the Case dealer.
/ DAVID BROWN power steerin needed #3
I've seen valve-in-cyl PS setup like that on fords... Besides.. DB went to case.. which is now CNH anyway...
I'll bet you can find a ford valve in cyl ps setup that you could adapt (torch, big hammer, welder ) to fit your needs.. OR.. hit a salvage yard like wengers of pa.
soundguy
/ DAVID BROWN power steerin needed #4
I worked at a dealer out in Pa a few years ago that serviced hundreds of those machines. A lot of the parts weren't easily available anymore but one source we did use a lot was a salvage yard in Meyerstown. I think their name was Wengers. They were very good about sending us parts we needed for the DB and other older tractors.
I had to reline clutches and brakes myself there for them too. I remember linings were available but not whole assemblies. Most of the steering systems I rebuilt were relatively easy and seals and things like that were on the shelf but I have had to bring work home with me a few times to make parts in my machine shop. You'd be amazed what a good machinist can make and it's not always very expensive.
(1) 20 Yard Roll Off Dumpster and (1) 30 Yard Roll Off Dumpster (A65579)
(1) 20 Yard Roll...
2016 INTERNATIONAL PROSTAR+122 6X4 ROAD TRACTOR (A64280)
2016 INTERNATIONAL...
2021 UTILITY VS2DX 53FT DRY VAN TRAILER (A59905)
2021 UTILITY VS2DX...
Skid Steer Bale Spear (A65640)
Skid Steer Bale...
John Deere Telescopic Lift Arms (A65640)
John Deere...
2016 WESTERN STAR 4700SF DUMP TRUCK (A59914)
2016 WESTERN STAR...
